Viewing Application Records of a Parameter Template
After a parameter template is applied to DDM instances, you can view its application records.
- Log in to the DDM console.
- Choose Parameter Templates in the navigation pane on the left.
- On the Default Templates page, locate the target parameter template and click View Application Record in the Operation column. Alternatively, on the Custom Templates page, choose More > View Application Record in the Operation column.
    You can view the name or ID of the DDM instance to which the parameter template is applied, as well as the application status, application time, and failure cause. Figure 1 Viewing application records
