Viewing Instance Metrics
Cloud Eye monitors the running status of DDM instances. You can view instance monitoring metrics on the DDM console.
Monitored data requires a period of time for transmission and display. The status of the monitored object displayed on the Cloud Eye page is the status obtained 5 to 10 minutes before. If you have created a DDM instance, wait for 5 to 10 minutes to view its monitored data on Cloud Eye.
- Log in to the DDM console.
- On the Instances page, locate the required instance and click More > View Metric in the Operation column.
Alternatively, click the instance name, on the displayed page, click View Metric in the upper right corner.
- In the instance list, click
in the front of the target instance. Locate a node and click View Metric in the Operation column. Figure 1 Viewing metrics
You can view instance metrics, including CPU usage, memory usage, network input throughput, network output throughput, QPS, and slow query logs. For details, see DDM Instance Metrics.
Figure 2 Metric details
