DDM Instance Metrics
This section describes metrics reported by DDM to Cloud Eye, metric namespaces, and dimensions. You can use APIs provided by Cloud Eye to query the metric information generated for DDM.
Namespace
SYS.DDMS
SYS.DDM is the namespace of DDM 1.0.
SYS.DDMS is the namespace of DDM 2.0.
DDM has been upgraded to version 2.0. The namespace is still SYS.DDM for existing users of DDM 1.0.
Metrics
| Metric ID | Metric Name | Description | Value Range | Monitored Object | Monitoring Interval (Raw Data) |
| ddm_cpu_util | CPU Usage | CPU usage of the DDM instance node | 0—100 | DDM nodes | 1 minute |
| ddm_mem_util | Memory Usage | Memory usage of the DDM instance node. | 0—100 | DDM nodes | 1 minute |
| ddm_bytes_in | Network Input Throughput | Incoming traffic per second of the DDM instance node | ≥ 0 | DDM nodes | 1 minute |
| ddm_bytes_out | Network Output Throughput | Outgoing traffic per second of the DDM instance node | ≥ 0 | DDM nodes | 1 minute |
| ddm_qps | QPS | Requests per second of the DDM instance node | ≥ 0 | DDM nodes | 1 minute |
| ddm_read_count | Reads | Read operations of the DDM instance node within each monitoring period | ≥ 0 | DDM nodes | 1 minute |
| ddm_write_count | Writes | Write operations of the DDM instance node within a monitoring period | ≥ 0 | DDM nodes | 1 minute |
| ddm_slow_log | Slow SQL Logs | Slow SQL logs of DDM-Core | ≥ 0 | DDM nodes | 1 minute |
| ddm_rt_avg | Average Response Latency | Average response latency of DDM-Core | ≥ 0 | DDM nodes | 1 minute |
| ddm_connections | Connections | Connections of DDM-Core | ≥ 0 | DDM nodes | 1 minute |
| ddm_backend_connection_ratio | Percentage of Active Connections | Percentage of active connections (from a DDM node to the target RDS instance) | 0—100 | DDM nodes | 1 minute |
| ddm_active_connections | Active connections | Active connections of each DDM instance node | ≥ 0 | DDM nodes | 1 minute |
| ddm_connection_util | Connection Usage | Percentage of active connections to each DDM instance node | 0—100 | DDM nodes | 1 minute |
| ddm_node_status_alarm_code | DDM Node Connectivity | Whether each DDM instance node is unavailable. The value can be 0 and 1. 0 indicates that the node is available, and 1 indicates that the node is unavailable. | 0 or 1 | DDM nodes | 1 minute |
| ddm_global_sequence_threshold_exceeded_count | Global Secondary Sequences Beyond Threshold | Number of global sequences whose usage exceeds 75%. Usage = Current value/Maximum value. The default threshold is 75%. The maximum value of a global sequence depends on the global sequence type. For example, the maximum value of BIGINT is 2^63-1. | ≥ 0 counts | DDM instances | 10 minutes |
Dimensions
| Key | Value |
| instance_id | DDM instance ID |
| node_id | DDM node ID |
