Updated on 2025-06-25 GMT+08:00
Customized Hints for Sort-based Aggregation
Command format:
/*+ use_sort_base_agg=true */ <GROUP BY statement>;
Description:
This hint supports sort-based aggregation. Compared with HashAgg, sort-based aggregation reduces memory usage by loading data by group.
Example:
/*+ use_sort_base_agg=true */ select pad from dbtest1 group by pad;
Constraints:
Only 3.1.3 and later versions are supported.
