Help Center/ Distributed Database Middleware/ User Guide/ SQL Syntax/ Unsupported Objects and Use Constraints
Updated on 2026-08-04 GMT+08:00
- Triggers
- Temporary tables
- DO statement
- Association with foreign keys
- RESET statement
- FLUSH statement
- BINLOG statement
- HANDLER statement
- SHOW WARNINGS statement
- Assignment operator :=
- Operators less than (<), equal sign (=), and greater than (>)
- Expression IS UNKNOWN
- INSTALL and UNINSTALL PLUGIN statements
- Cross-shard stored procedures and custom functions
- Modifying database names and sharding field names and types is not allowed.
- Most of SHOW statements such as SHOW PROFILES and SHOW ERRORS
- Table maintenance statements, including CHECK, CHECKSUM, OPTIMIZE, and REPAIR TABLE
- Statements for assigning a value to or querying variable session
Example:
set @rowid=0;select @rowid:=@rowid+1,id from user;
- SQL statements that use -- or /*...*/ to comment out a single line or multiple lines of code
- The result of the REPEAT function contains a maximum of 1,000,000 characters (in version 3.0.9 or later).
Permission Levels
- Global level (not supported)
- Database level (supported)
- Table level (supported)
- Column level (not supported)
- Subprogram level (not supported)
- User level (supported)
Parent topic: SQL Syntax
