Overview
Dedicated Computing Cluster (DCC) provides dedicated, physically isolated computing resource pools on the cloud service platform, allowing you to use physical server resources exclusively. You can also create ECSs on the physical servers.
DCCs must be used in DeCs. So, you need to apply for a DeC before using your DCCs. Then you can centrally manage your DCCs in the DeC.
This section describes how to enable and use a DCC.
