Updated on 2025-09-16 GMT+08:00
Creating an Alarm Rule
You can configure alarm rules to customize monitored objects and notification policies and to learn connection status at any time.
- On the console homepage, click
in the upper left corner and select the desired region and project.
- In the service list, choose Management & Governance > Cloud Eye.
- In the navigation pane on the left, choose Alarm Management > Alarm Rules.
- On the Alarm Rules page, click Create Alarm Rule.
- Click Create.
After the alarm rule is created, you will be notified when an alarm is triggered.
Parent topic: Cloud Eye Monitoring
