Help Center/ Direct Connect/ User Guide/ Virtual Interfaces/ Managing Virtual Interface Peers
Updated on 2026-01-06 GMT+08:00
Overview
A virtual interface peer is a configuration of a virtual interface to support the IPv4/IPv6 dual stack and is used to connect the customer gateway to the virtual gateway. A virtual interface peer is automatically created when you create a virtual interface.
A virtual interface has at least one virtual interface peer, and the last virtual interface peer cannot be deleted.
Viewing a Virtual Interface Peer
  1. Go to the Virtual Interfaces page.
  2. In the upper left corner of the page, click and select a region and project.
  3. Locate the virtual interface and click its name.
  4. In the lower part of the page, locate the virtual interface peer you want to view and view its details.
Modifying a Virtual Interface Peer
  4. In the lower part of the page, locate the virtual interface peer you want to modify and click Modify in the Operation column.
  5. Modify the virtual interface peer. An IPv4 virtual interface peer is used as an example here.
    Figure 1 Modifying a virtual interface peer
  6. Click OK.
