Help Center/ Direct Connect/ User Guide/ Virtual Interfaces/ Managing Virtual Interfaces
Updated on 2026-01-06 GMT+08:00
You can view, modify, and delete a virtual interface.
Viewing a Virtual Interface
  1. Go to the Virtual Interfaces page.
  2. In the upper left corner of the page, click and select a region and project.
  3. In the virtual interface list, locate the virtual interface and click its name to go to the Basic Information page of the virtual interface.
    Figure 1 Viewing a virtual interface
Modifying a Virtual Interface
  3. In the virtual interface list, locate the virtual interface you want to modify and click Modify in the Operation column.
    Figure 2 Modifying virtual interface 1
    You can also click the name of the virtual interface to go to the Basic Information page of the virtual interface, where you can modify the name, bandwidth, rate limiting, priority, and peer of the virtual interface.
    For details about virtual interface peers, see Managing Virtual Interface Peers.
    Figure 3 Modifying virtual interface 2
    If multiple virtual interfaces are associated with one Direct Connect device, the load is balanced among virtual interfaces with the same priority, while virtual interfaces with different priorities are working in active/standby pairs.
Deleting a Virtual Interface
  3. In the virtual interface list, locate the virtual interface you want to delete and click Delete in the Operation column.
  4. In the displayed dialog box, enter DELETE and click OK.
    Figure 4 Deleting a virtual interface
