Updated on 2025-09-16 GMT+08:00
Deleting a Virtual Interface
You can delete a virtual interface if you do not need it any longer.
- Go to the Virtual Interfaces page.
- In the upper left corner of the page, click
and select a region and project. - In the virtual interface list, locate the virtual interface you want to delete and click Delete in the Operation column.
- In the displayed dialog box, enter DELETE and click OK.
Figure 1 Deleting a virtual interface
Parent topic: Virtual Interfaces
