Updated on 2023-07-06 GMT+08:00
Renewing a Connection
You can renew the subscription when a connection is about to expire.
- On the console homepage, click in the upper left corner and select the desired region and project.
- Hover on to display Service List and choose Networking > Direct Connect.
- In the navigation pane on the left, choose Direct Connect > Connections.
- Locate the connection you want to renew and choose More > Renew in the Operation column.
- Set the duration that you want to renew the connection and click Pay. Then pay the order as prompted.
Parent topic: Connections
