Updated on 2026-07-07 GMT+08:00
Instance Management
Viewing the Instance List
  1. Log in to the DBSS console.
  2. Click in the upper left corner on the displayed page and select a region.
  3. In the navigation tree on the left, choose Database Security Audit (Enhanced O&M).
    Figure 1 Instance list
    Table 1 Instance parameters
    Instance Name/Resource ID
    Instance name and resource ID.
    Status
    Status of the instance.
    Instance Edition
    Edition to which the instance belongs. It can be:
    • Series 1
    • Series 2
    Private IP Address
    Private IP address of the instance.
    EIP
    EIP bound to the instance. If no EIP is bound, -- is displayed.
    Instance Version
    Version of the database O&M instance when you create it. Instance versions may vary depending on the creation time.
    The instance version will affect:
    • Supported database types
    • Supported database versions
    Billing Mode
    The billing mode is yearly/monthly.
Viewing Instance Details
Click the Instance Name/Resource ID of the instance to be viewed. The instance details page is displayed.
Figure 2 Instance details
Table 2 Instance details
Instance information
Basic Information
Instance ID
Instance ID, which is automatically generated
Status
AZ
AZ where the instance resides.
Details
Basic Information
Name
Name of the instance. To change it, click next to the instance name.
Specifications
Performance specifications of the instance.
Instance Version
Instance Edition
  • Series 1
  • Series 2
Network Configuration
VPC
VPC where an instance resides.
Security Group
Security group where an instance resides.
Subnet
Subnet where an instance resides.
Virtual IP Address
Transaction Information
Billing Mode
Last Transaction Order
Order No. of the latest transaction for the instance. Click the order No. to view the transaction details of the instance.
Created
Time when an instance is created.
Expires At
Time when the instance expires.
Upon Expiration
Policy used after the instance has expired.
Remote Login
  • Method 1: Click Remote Login in the Operation column of the instance you want to remotely log in to.
  • Method 2: Click Instance Name/Resource ID of the instance you want to remotely log in to. In the displayed page, click Remote Login in the upper right corner.
Renewal
  1. Click Renew in the Operation column of the instance you want to renew. In the displayed dialog box, click Yes. The Renew page is displayed.
  2. Confirm the instance information, and select the renewal duration, auto-renewal, and renewal date.
  3. Click Pay.
  4. Confirm the order information.
  5. Confirm the information and click Pay.
Enabling an Instance
  • To log in to the instance whose Status is Disabled, enable the instance first.
  • To log in to the instance whose Status is Abnormal, try to enable the instance to restore it first.
Enabling an Instance Operations
  • Method 1: In the Operation column, choose Enable.
  • Method 2: Click Instance Name/Resource ID of the instance you want to enable. In the displayed page, click Enable in the upper right corner.
Restarting an Instance
  • For maintenance purposes, if the system becomes abnormal, you can restart the instance to restore its availability.
  • Only the instance in the Running status can be restarted.
  • Restarting an instance will interrupt system services for about 5 minutes. During this period, the status of the instance is Restarting.
  • The instance is not available when it is being restarted.
Restarting an Instance Operations
  • Method 1: In the Operation column, choose More > Restart.
  • Method 2: Click Instance Name/Resource ID of the instance you want to restart. In the displayed page, click Restart in the upper right corner.
Disabling an Instance
  • Only the instance in the Running status can be disabled.
  • Once the instance is disabled, you will not be able to log in to the system.
Disabling an Instance Operations
  • Method 1: In the Operation column, choose More > Disable.
  • Method 2: Click Instance Name/Resource ID of the instance you want to enable. In the displayed page, click Disable in the upper right corner.
Changing a Security Group
  1. In the Operation column, choose More > Change Security Group.
  2. In the displayed dialog box, select Security Group and click OK.
Unbinding the EIP
  • If you want to bind another EIP to the instance or release the current EIP, unbind it from the instance first.
  • After the EIP is unbound, you cannot use the EIP to log in to the system.
  • For details about how to bind an EIP, see Binding Elastic Public IP (EIP).
Unbinding the EIP Operation
  1. In the Operation column, choose More > Unbind EIP.
  2. In the displayed dialog box, click OK.
  3. After the unbinding is successful, no IP address information is displayed in the EIP column, and Remote Login is grayed out.
Resetting the Password
  1. In the Operation column, choose More > Reset Password.
  2. In the displayed dialog box, set the new password, confirm it, and click OK.
  3. After the password is reset, you need to use the new password to log in to the system.
Enabling Auto-Renewal
Auto-renewal can be enabled only for instances that have not enabled the function.
  1. Choose More > Enable Auto-Renewal in the Operation column.
  2. In the displayed dialog box, click Yes. The Enable Auto-Renewal page is displayed.
  3. Confirm the instance information, select the auto-renewal period, set the number of auto-renewals, and click OK.
Modifying Auto-Renewal Settings
Auto-renewal settings can only be modified for instances with auto-renewal enabled.
  1. Choose More > Modify Auto-Renewal in the Operation column.
  2. In the displayed dialog box, click Yes. The Modify Auto-Renewal page is displayed.
  3. Confirm the instance information, select a renewal mode, and click OK.
Unsubscribing from the Instance
Unsubscription is not allowed while a transaction for the instance is in progress.
  1. In the Operation column, choose More > Unsubscribe.
  2. In the displayed dialog box, confirm the unsubscription information and click Yes to initiate the unsubscription process. After unsubscription is complete, the instance will not be displayed in the list.
