Desensitization Log
Viewing Log
- Logging In to the Database Encryption System using the system administrator account audadmin.
- In the left navigation bar, select Log > Desensitization Log.
- You can view logs on the page and search by criteria.
Page parameter description: Refer to the Operation Log above.
Figure 1 Viewing the desensitization operation log
Export Log
Users can click the button on the page to download the log to their local device.
Data Integrity Check
Users can click Data Integrity Check to check whether the log has been modified by other actions (such as editing by other systems or manual modifications).
