System Backup
The backup configuration information saves all configuration details, including System Management, asset management, sensitive data discovery, and key management. To ensure the system's disaster recovery capability, it is recommended to regularly back up system configuration information.
Backup Configuration Information
- Logging In to the Database Encryption System using the system administrator sysadmin account.
- In the left navigation bar, select System Management > System Backup to enter the interface.
- Click the Database Export tab, select the backup save location from the dropdown menu in the Backup Method dialog box, and then export the backup.
Configure Information Again
By importing a configuration file, you can restore configuration information to a specific backup point. This is typically used for disaster recovery or device migration.
- Click Database Import, select the SQL file, then click Confirm to proceed with the import. Wait for completion.
