Creating an Organization
An organization can manage the members in it. Create an organization as needed for better management.
- Log in to a database encryption and access control instance as the sysadmin user.
- In the navigation pane on the left, choose System Management > Organization Management.
- Click Add Organization on the left.
- Configure the parameters in the displayed dialog box.
Figure 1 Parameters for adding an organization
Table 1 Parameters for adding an organization Parameter
Organization Name
Set the organization name.
Organization ID
Set the internal code.
Parent Organization
Choose the parent department from the drop-down list.
If this parameter is not configured, the created organization is the level-1 department by default.
- Click Confirm.
