Updated on 2025-11-27 GMT+08:00
Interconnecting with KMS
You can obtain the key sources from Key Management Service (KMS). Currently, Huawei Cloud is supported.
KMS is a cryptographic platform that provides key management services for third-party cryptographic applications.
  1. Log in to a database encryption and access control instance as the sysadmin user.
  2. In the navigation pane on the left, choose Key Management > KMS Management.
  3. Click the Huawei Cloud tab.
  4. Configure the parameters for interconnecting with KMS. For details, see Table 1.
    Table 1 Parameters
    Region
    Region of Huawei Cloud. You can obtain it from the URL of the KMS console, as shown in Figure 1.
    Username
    IAM username
    User Password
    IAM user password
    Primary User Account
    IAM tenant name, that is, the account to which the IAM user belongs.
    Key Name
    Alias of the KMS key
    Figure 1 KMS console parameters
  5. Click Connection Test.
  6. After KMS is interconnected, click Save.
Follow-up Operations
After the configuration, you can select it by clicking KEY_Service when initializing a key. For details, see Initializing a Key.
