Updated on 2025-11-27 GMT+08:00
Adding Data Assets
After data assets (databases) are added to the system, you can identify, encrypt, decrypt, and mask sensitive data in the databases.
This section uses the MySQL database as an example. Add data assets based on the site requirements.
Constraint
Table 1 Data sources and versions that can be managed by database encryption
Database
Version
MySQL
5.5, 5.6, 5.7, 8.0, 8.0.13+
Oracle
11.1, 11.2, 12c, 19c
SQLServer
2012, 2016
PostgreSQL
9.4, 11.5
DM
6, 7.6, 8.1
Kingbase
V8 R3, V8 R6
MariaDB
10.2
A
TDSQL
5.7
TBASE
V2.15.17.3
RDS_MYSQL
5.6, 5.7, 8.0
RDS_PostgreSQL
11
HotDB
2.5.6
HighGO
4.5
DWS
8.1
Table 2 Database account permissions for database encryption
Database
System Catalog Requiring the SELECT Permission
Database Account Permission
MySQL
mysql.user
performance_schema.*
select
insert
create
update
delete
drop
alter
index
RDS_MYSQL
mysql.user
select
insert
create
update
delete
drop
alter
index
TDSQL
mysql.user
select
insert
create
update
delete
drop
alter
index
MariaDB
mysql.user
select
insert
create
update
delete
drop
alter
index
DM
SYS.ALL_SUBPART_KEY_COLUMNS
SYS.ALL_USERS
SYS.ALL_CONS_COLUMNS
SYS.ALL_CONSTRAINTS
SYS.ALL_TABLES
SYS.ALL_TABLE_COLUMNS
SYS.ALL_COL_COMMENTS
SYS.ALL_PART_KEY_COLUMNS
SYS.ALL_IND_COLUMNS
SYS.ALL_INDEXS
V$VERSION
V$LOCK
SYS.DBMS_LOB
SYS.DBMS_METADATA
The user role must be dba.
postgreSQL
pg_catalog.pg_class
pg_catalog.pg_index
pg_catalog.pg_user
pg_catalog.pg_indexes
information_schema.columns
information_schema.sequences
information_schema.tables
pg_catalog.pg_sequence
The user must be the table owner or the dba role.
RDS_PostgreSQL
pg_catalog.pg_class
pg_catalog.pg_index
pg_catalog.pg_user
TBASE
pg_catalog.pg_class
pg_catalog.pg_index
pg_catalog.pg_user
GAUSSDB
pg_catalog.pg_class
pg_catalog.pg_index
pg_catalog.pg_user
Kingbase 8.6 (pg)
pg_catalog.pg_class
pg_catalog.pg_index
pg_catalog.pg_user
pg_catalog.pg_matviews
KINGBASE 8.3
sys_catalog.sys_class
sys_catalog.sys_index
sys_catalog.sys_user
sys_catalog.sys_indexes
sys_catalog.sys_sequence
sys_catalog.sys_matviews
Oracle
SYS.DUAL
SYS.ALL_USERS
SYS.ALL_CONSTRAINTS
SYS.ALL_TABLES
SYS.ALL_IND_COLUMNS
SYS.ALL_INDEXS
SYS.V_$INSTANCE
SYS.DBMS_LOB
SYS.DBMS_METADATA
DBA_TABLES
DBA_TAB_COLS
SQLserver
sys.tables
sys.indexes
sys.index_columns
sys.default_constraints
sys.systypes
sys.extended_properties
sys.foreign_key_columns
sys.check_constraints
sys.foreign_keys
sys.columns
sys.objects
sys.all_columns
sys.types
sys.syslogins
sys.all_objects
sys.schemas
sys.key_constraints
sys.computed_columns
sys.triggers
sys.partition_schemes
sys.dm_sql_referencing_entities
schemaSelect
schemaInsert
schemaUpdate
schemaAlter
createTable
VIEW SERVER STATE
SELECT permission of the encrypted table
INSERT permission of the encrypted table
ALTER permission of the encrypted table
HighGO
pg_catalog.pg_class
pg_catalog.pg_index
pg_catalog.pg_user
DWS
pg_catalog.pg_class
pg_catalog.pg_index
pg_catalog.pg_user
  1. Log in to a database encryption and access control instance as the sysadmin user.
  2. In the navigation pane, choose Assets Management > Data Source Management.
  3. Click Add Data Source in the upper right corner.
  4. In the Add Data Source dialog box, configure asset information. For details, see Table 3.
    Table 3 Parameters for adding a data source
    Database Information
    Data Source
    Customized data asset name.
    Data Source Type
    Select a database type from the drop-down list box. For details about supported database versions, see Constraint.
    Data Source Version
    Select a database version from the drop-down list box.
    Read/Write Separation/RAC
    If the database is deployed in read/write isolation mode, select this option and configure information about the secondary database node.
    Data Source Address
    IP address of the database.
    Data Source Port
    Connection port of the database.
    Proxy Address
    Select a proxy address from the drop-down list box, that is, the IP address for accessing and controlling the database.
    Proxy Port
    Set a proxy port. O&M personnel access the database through the proxy IP address and proxy port.
    • The value range is 1025 to 65535.
    • You can set any idle port within the range. Ports that have been used by other data assets cannot be used. For example, if data asset A uses port 14000, data asset B cannot use this port.
    You can click Auto Assign to let the system automatically assign idle proxy ports.
    Database/Instance/SID/Service/Schema
    Set the database, instance name, SID, service name, or schema.
    Database Account
    Database login user.
    Database Password
    Password for logging in to the database.
    Encryption Parameters
    Encryption Mode
    • Asset encryption mode. The options are as follows:
      • One Key Per Asset: The DEKs of assets are the same. Connection query and cross-database query are supported.
      • One Key Per Column: The DEKs of assets are different. Join query and cross-database query are not supported.
    Default Display without Permission
    • Set what is displayed to the users who do not have the permissions to access the database. The options are as follows:
      • Ciphertext: Ciphertext is displayed. The encoding format is Base64 or hexadecimal. For details, see Setting Encryption Parameters.
      • Default Data: Default data is displayed. You need to set the default data of the string type.
      • NULL: The content is blank.
    (Optional) Host Information
    After the monitoring threshold is configured, the system encrypts data in batches only within the monitoring threshold of the database server. If the resource usage exceeds the threshold, the system stops encrypting data to reduce the impact on services. You are advised to set the following parameters if possible.
    Host IP
    Host IP address.
    Host Port
    SSH service port of the host. The default SSH service port is 22.
    Username
    Username for logging in to the host.
    Password
    Password for logging in to the host.
    Character Set
    Character set used by the host, which is automatically obtained after the host is connected.
    Host Operating System
    Host OS, which is automatically obtained after the host is connected.
    Kernel
    Host kernel, which is automatically obtained after the host is connected.
    Monitoring Threshold
    Thresholds for host monitoring metrics (CPU, memory, I/O, and network). The system encrypts database data only within the threshold to reduce the impact on services.
    Log Information
    Database Log File Name
    Path and name of the database log file. Example: /usr/local/mysql/binlogs/mysql-bin.000060
  5. (Optional) After the configuration is complete, click Test Database Connection and check whether the database can be connected.
  6. (Optional) Click Test Account Permission to check whether the database account permission meets the encryption requirements.
    If the database account permission does not meet the encryption requirements, configure the database account permission by referring to Table 2.
  7. (Optional) If the host information is configured, click Test Host Connection. Check whether the host can be connected and whether its character set and OS can be automatically obtained.
  8. Click Save to save the data asset configuration.
    After the asset is added, you can view its information in the data source list, as shown in Figure 1.
    Figure 1 Data source list
  9. In the list, click to enable the database proxy.
    After this function is enabled, you can access the database through the proxy IP address and proxy port.
Related Operations
  • Click in the Policy Configuration column of the data source list. The encryption task configuration page is displayed. You are advised to identify sensitive data before configuring an encryption task. For details, see Scanning Sensitive Data in Assets.
  • Click in the Policy Configuration column of the data source list. The masking rule configuration page is displayed. You are advised to identify sensitive data before configuring a masking rule. For details, see Scanning Sensitive Data in Assets.
  • Click Edit in the Actions column of the data source list to modify data asset information.
  • Click Delete in the Actions column of the data source list to delete unnecessary data assets.
    If a message is displayed, indicating that the table structure of the current database is not rolled back, perform the operations in Rolling Back the Table Structure or Configuring a Decryption Task based on site requirements.
