Help Center/
Database Security Service/
User Guide/
Database Security Encryption Management/
Instance Management/
Unbinding an EIP
Updated on 2025-04-16 GMT+08:00
Unbinding an EIP
To rebind or release an EIP, you need to unbind the EIP from the instance first. After an EIP is unbound from an instance, you cannot use the EIP to log in to database encryption and access control.
- Click
in the upper left corner and select a region or project.
- In the navigation pane on the left, click
and choose .
- Locate the row that contains the desired instance and choose in the Operation column.
- In the displayed Unbind EIP dialog box, click OK.
Parent topic: Instance Management
