Updated on 2025-04-16 GMT+08:00
Enabling an Instance
The instance needs to be started in the following scenarios:
  • When the running status of an instance is Disable, you need to start the instance if you want to log in to the instance using database encryption and access control.
  • If the running status of an instance is Abnormal, you can start the instance if you need to log in to the instance using database encryption and access control.
  2. Click in the upper left corner and select a region or project.
  3. In the navigation pane on the left, click and choose Security & Compliance > Data Security Center.
  4. Locate the row that contains the desired instance, and click in the Operation column.
