Updated on 2026-08-04 GMT+08:00
Step 5: Enable Database Audit
By default, database audit complies with a full audit rule, which is used to audit all databases that are connected to the database audit instance. You can enable audit and check audit results. For details, see Viewing Audit Data.
The status of the agent is Running.
Enabling Database Audit
  1. Log in to the DBSS console.
  2. Click in the upper left corner on the displayed page and select a region.
  3. In the navigation tree on the left, choose Databases.
  4. Select a database audit instance from the Instance drop-down list.
  5. In the database list, click Enable in the Operation column of the database you want to audit.
    The Audit Status of the database is Enabled. You do not need to restart the database.
    Figure 1 Enabling database audit
    Table 1 Parameters
    Database Information
    Name, type, and version of a database
    Character Set
    Encoding character set of the database
    IP Address (Domain Name)/Port
    The IP address and port number of the database.
    Instance
    Database instance name
    OS
    Operating system of the database
    Audit Status
    Audit status of the database. The options are as follows:
    • Enabled
    • Disabled
    Agent
    • Click View Agent to check the agent information. For details, see Viewing an Agent.
    • Click Add to add an agent for the database. For details, see Adding an Agent.
    Operation
    Operation that can be performed on a database.
Verifying Audit Results
  1. Run an SQL statement (for example, show databases) in the target database.
  2. In the navigation tree on the left, choose Data Reports.
  3. In the Instance drop-down list, select the instance that audits the target database.
  4. Click the Statements tab.
  5. Expand the drop-down list and select All time, Last 30 minutes, 1 hour, Today, 7 days, 30 days, or set a custom time range. Click the search box, select a filter, or enter a keyword.
    Figure 2 Viewing SQL statements
    Table 2 SQL statement parameters
    SQL Statements
    Entire SQL statement.
    Client IP Address
    IP address of the client where an SQL statement is executed
    Database IP Address/Domain Name
    IP address or the domain name of the database where an SQL statement is executed
    Database User
    Database user for executing an SQL statement
    Name
    Database name for executing an SQL statement
    Risk Level
    Risk level of executing an SQL statement.
    • High
    • Medium
    • Low
    • No risk
    Rule
    Name of the rule for executing an SQL statement.
    Operation Type
    Type of an SQL statement operation
    Result
    Response to an SQL statement
    Generated
    Time when an SQL statement is generated
    Operation
    Operations that can be performed on SQL statements
    • Add to Whitelist: Add an SQL statement to the whitelist.
References
If the network communication between the agent and the database audit instance is normal but the audit still fails, rectify the fault by referring to Database Audit Is Running Properly But Generates No Audit Records.
