Configuring Risky Operation Rules
Database audit has four built-in detection rules, including database reduction detection, slow SQL statements detection, batch data tampering detection, and batch data deletion detection, helping you detect database security risks in a timely manner. You can also add risky operations and customize detection rules.
One piece of audited data can match only one risky operation rule.
The database audit instance is in the Running state.
Constraints and Limitations
- Before enabling the risky operation, ensure that its status is Disabled.
- Before disabling the risky operation, ensure that its status is Enabled.
- If the risky operation is a system rule, setting priorities, editing, or deleting operations are not supported.
Adding a Risky Operation Rule
- Select a region, click
, and choose . The Dashboard page is displayed. - In the navigation tree, choose Rules.
- In the Instance drop-down list, select an instance to add risky operations.
- Click the Risky Operation tab.
- Click Add above the risky operation list.
- On the Add Risky Operation page, set the basic information and IP address or IP range. For details about related parameters, see Table 1.Figure 1 Configuring basic information and IP addresses or IP address segments
Table 1 Parameters Parameter
Example Value
Name
Custom name of a risky operation
test
Risk Severity
Severity of a risky operation. The options are as follows:
- High
- Moderate
- Low
- No risks
High
Status
Status of a risky operation
: Enabled
: Disabled
Select Database
Database that the risky operation will be applied to
You can select ALL or a specific database.
Exception Client IP Address or IP Range
To report risky operation alarms set by users, configure the client IP address or IP address range that is not in the trusted client IP address or IP address range.
The IP address can be an IPv4 address (for example, 192.168.1.2) or an IPv6 address (for example, fe80:0000:0000:0000:0000:0000:0000:0000).
192.168.xx.xx
IP address or IP address range of the client
The IP address can be an IPv4 address (for example, 192.168.1.1) or an IPv6 address (for example, fe80:0000:0000:0000:0000:0000:0000:0000).
192.168.xx.xx
- Set the operation type, operation object, and execution result. For details about related parameters, see Table 2.Figure 2 Setting the operation type, operation object, and execution result
Table 2 Parameters for adding a risk rule Parameter
Example Value
Operations
Type of a risky operation, including Login and Operation
When you select the Operation check box, you can select All operations or the operations in DDL, DML, and DCL.
Operation
Objects
Enter the target database, target table, and field information after clicking Add Operation Object. Click OK to add an operation object.
Results
Set Affected Rows and Operation Duration. The operation conditions are as follows:
- Greater than
- Less than
- Equal To
- Greater than or equal to
- Less than or equal to
- Click Save.
Viewing Risk Operation Rules
- In the Instance drop-down list, select an instance to view risky operations.
- Click the Risky Operations tab.
- View the risky operation information. For details about related parameters, see Table 3.
You can select an attribute from the search box above the list or enter a keyword to search for a specified risky operation.
Figure 3 Viewing the risky operation
Table 3 Parameters Parameter
Name
Name of the risky operation
Rule Category
Risky operation type. The options are as follows:
- Custom rules
- System rules
Priority
Priority of a risky operation.
Category
Category of the risky operation
Feature
Feature of the risky operation
Risk Level
Risk level of a risky operation. The options are as follows:
- High
- Medium
- Low
- No risks
Status
Status of the risky operation. The options are as follows:
- Enabled
- Disabled
You can perform the following operations on risky operations as required:
- Enable
Locate the row that contains the risky operation to be enabled, and click Enable in the Operation column. The operation will be audited.
- Edit
Locate the row that contains the risky operation to be edited, click Edit in the Operation column, and modify the operation in the displayed dialog box.
- Disable
Locate the row that contains the risky operation to be disabled, click Disable in the Operation column, and click OK in the displayed dialog box. When a risky operation is disabled, the risky operation rule will not be executed in the audit.
- Deleting
Locate the row that contains the risky operation to be deleted, click Delete in the Operation column, and click OK in the displayed dialog box. You need to add the risky operation again if a risky operation is deleted and you need to audit its rule.
Setting the Risk Rule Priority
- In the Instance drop-down list, select an instance to set risky operation priority. Click the Risky Operations tab.
- In the row containing the risky operation for which you want to set a priority, click
in the Priority column.Figure 4 Setting the priority
- Click OK.Figure 5 Setting the priority
