Updated on 2026-09-24 GMT+08:00
Process Overview
This section describes the types and versions of databases that support agent installation and agent-free protection, as well as the process of configuring database audit.
Database audit supports auditing user-installed databases on ECS/BMS as well as RDS databases on Huawei Cloud.
Notes and Constraints
Databases That Do Not Need Agents
Databases of some types and versions can be audited without using agents, as shown in Table 1.
Table 1 Agent-free relational databases
Database Type
Supported Edition
All editions are supported by default.
RDS for SQL Server
RDS for MySQL
  • 5.6 (5.6.51.1 or later)
  • 5.7 (5.7.29.2 or later)
  • 8.0 (8.0.20.3 or later)
DWS
  • 8.2.0.100 or later
PostgreSQL
NOTICE:
If the size of an SQL statement exceeds 4 KB, the SQL statement will be truncated during auditing. As a result, the SQL statement is incomplete.
  • 17 (17.9 or later)
  • 16 (16.10 or later)
  • 15 (15.10 or later)
  • 14 (14.4 or later)
  • 13 (13.6 or later)
  • 12 (12.10 or later)
  • 11 (11.15 or later)
  • 9.6 (9.6.24 or later)
  • 9.5 (9.5.25 or later)
RDS for MariaDB
  • DBSS without agents is easy to configure and use, but the following functions are not supported:
    • Successful and failed login sessions cannot be counted.
    • The port number of the client for accessing the database cannot be obtained.
  • Data Warehouse Service (DWS) has the permission control policy for the log audit function. Only Huawei Cloud accounts and users with the Security Administrator permission can enable or disable the DWS database audit function.
Databases That Need Agents
Database audit supports the following database types and versions, as shown in Table 2.
Table 2 Database types and editions supported by database audit
Database Type
Edition
MySQL
  • 5.0, 5.1, 5.5, 5.6, and 5.7
  • 8.0 (8.0.11 and earlier)
  • 8.0.30
  • 8.0.33
  • 8.0.35
  • 8.1.0
  • 8.2.0
Oracle
  • 11g
    11.1.0.6.0, 11.2.0.1.0, 11.2.0.2.0, 11.2.0.3.0, and 11.2.0.4.0
  • 12c
    12.1.0.2.0, 12.2.0.1.0
  • 19c
PostgreSQL
  • 7.4
  • 8.0, 8.1, 8.2, 8.3, and 8.4
  • 9.0, 9.1, 9.2, 9.3, 9.4, 9.5, and 9.6
  • 10.0, 10.1, 10.2, 10.3, 10.4, and 10.5
  • 11
  • 12
  • 13
  • 14
SQL Server
  • 2008
  • 2012
  • 2014
  • 2016
  • 2017
8.0
DWS
  • 1.5
  • 8.1
DAMENG
DM8
KINGBASE
V8
SHENTONG
V7.0
GBase 8a
V8.5
GBase 8s
V8.8_3.3.0_RHEL6
Gbase XDM Cluster
V8.0
Greenplum
V6.0
HighGo
V6.0
  • 1.3 Enterprise Edition
  • 1.4 Enterprise Edition
  • 2.8 Enterprise Edition
  • 3.223 Enterprise Edition
MongoDB
V5.0
DDS
4.0
Hbase
(Supported by CTS instance 23.02.27.182148 and later versions)
  • 1.3.1
  • 2.2.3
Hive
  • 1.2.2
  • 2.3.9
  • 3.1.2
  • 3.1.3
MariaDB
10.6
TDSQL
10.3.17.3.0
Vastbase
G100 V2.2
TiDB
  • V4
  • V5
  • V6
  • V7
  • V8
Configuring Database Audit
Create a database audit instance, connect the instance with the target database, and enable database audit.
Figure 1 Process
Table 3 Procedure of configuring database audit without installing agent
Step
Configuration
Adding a Database
After purchasing DBSS, you need to add the database to be audited to the instance.
2
Enabling Database Audit
Enable database audit and connect the added database to the database audit instance.
3
Viewing Audit Data
By default, database audit complies with a full audit rule, which is used to audit all databases that are connected to the database audit instance. You can view the audit result on the database audit page.
NOTICE:
You can set database audit rules as required. For details about how to configure an audit rule, see Configuring an Audit Scope Rule.
Figure 2 Process
Table 4 Procedure of configuring database audit by installing the agent
Step
Configuration
Step 1: Add a Database
Purchase database audit. Add a database to the database audit instance and enable audit for the database.
2
Step 2: Add an Agent
Select an agent addition mode.
Database audit supports auditing databases built on ECS, BMS, and RDS on Huawei Cloud. Select an agent add mode based on your database deployed on Huawei Cloud.
3
Step 3: Download and Install the Agent
Download and then install the agent on the database or application based on the add mode you chose.
4
Step 4: Add a Security Group Rule
Configure TCP (port 8000) and UDP (ports 7000 to 7100) in the security group inbound rule of the database audit instance to allow the agent to communicate with the audit instance.
5
Step 5: Enable Database Audit
6
Viewing Audit Data
NOTICE:
Deploying the Database Audit Agent in a Container
For a database of any types and versions, you can deploy the agent using a container to enable database audit.
For details, see Deploying the Database Audit Agent in a Container
Verifying the Result
When you connect the added database to the database audit instance, database audit records all operations performed on the database. You can view the audit result on the database audit page.
References
