Updated on 2025-11-27 GMT+08:00
Step 1: Buy Database Security Encryption
This section describes how to buy a database encryption instance. The instance can be billed on a yearly/monthly basis.
Limitations and Constraints
Database encryption and access cannot be used across regions. The database to be encrypted and accessed must be in the same region as the purchased instance.
  2. Select a region, click , and choose Security & Compliance > Database Security Service. The Dashboard page is displayed.
  3. In the upper right corner of the page, click Buy DBSS.
  4. (Optional) Enter the purchase information.
    Table 1 Basic configuration parameters
    Service Type
    The value is fixed at Database Audit Service.
    Billing Mode
    Only the yearly/monthly mode is available.
    Region
    Select the region where the instance is located. Regions are geographic areas isolated from each other. Resources are region-specific and cannot be used across regions through internal network connections. For low network latency and quick resource access, select the nearest region.
    AZ Type
    Only general AZs are supported.
    AZ
    An AZ is a physical location that uses an independent power supply and network. AZs in the same region can communicate with each other over an intranet.
    You can select random allocation or specify an AZ.
    Standby AZ
    Table 2 Edition specifications
    Edition
    Select Database Audit Encryption Enhanced Edition under advanced edition.
    The specifications are as follows:
    • Asset quantity: A maximum of 10 databases are supported.
    • System resources:
      • CPU: 16 vCPUs
      • Memory: 32 GB
    • Encryption/decryption performance: 40,000 QPS
    • Maximum concurrent connections: 3000
    Figure 1 Network configuration
    Table 3 Network configuration parameters
    Example Value
    VPC
    Select the VPC to be associated.
    A VPC facilitates internal network management and configuration, and allows you to perform secure and quick network changes. It is recommended that the VPC be the same as that of the agent node.
    Security Group
    This parameter is mandatory when Deployed Location is set to Huawei Cloud.
    Security groups are used for access control.
    NOTICE:
    The security group must have rules to allow TCP port 9595 in the inbound direction.
    Subnet
    A subnet is a range of IP addresses in your VPC. All of the resources in a VPC must be deployed in subnets.
    Subnets cannot be used across geolocations. A general AZ cannot use the subnet of an edge AZ, and an edge AZ cannot use the subnet of a general AZ.
    Assign IPv4 Address
    Select an IPv4 address.
    Automatically assign IP address
    (Optional) EIP
    Select the EIP bound to the instance.
    IP address of the active node
    This parameter is mandatory when Deployed Location is set to outside Huawei Cloud.
    Enter the IP address of the active node.
    IP address of the standby node
    Enter the IP address of the standby node.
    Floating IP address
    Enter a floating IP address.
    Figure 2 Advanced configuration and login information
    Table 4 Parameters
    Example Value
    Name
    The name is automatically generated. You can also customize the name.
    Instance Type
    Currently, only the active/standby mode is supported.
    Primary/Standby
    Remarks (Optional)
    Remarks about the instance.
    Username
    Default username.
    sysadmin
    Login Password
    Set the password for logging in to the instance.
    The password must contain:
    • Contains 8 to 26 characters.
    • The password must contain at least two of the following types of characters: uppercase letters, lowercase letters, digits, and the following special characters: ~!@#$%^&*()_+`=-[]{}|;':,".<>?/\
    • The password should be different from the username or the username spelled backwards.
    Confirm Password
    Enter the confirm password, which must be the same as the login password.
    Figure 3 Required duration
    After you select Auto-renew, the system automatically renews the instance upon expiry if your account balance is sufficient. You can continue to use the instance. Table 5 describes the auto-renewal period.
    Table 5 Auto-renewal period description
    Required Duration
    Auto-renewal Period
    1/2/3/4/5/6/7/8/9 months
    1 month
    1/2/3 years
    1 year
  5. Confirm the configuration and click Next.
    For any doubt about the pricing, click Pricing details to understand more.
  6. On the Details page, read the Database Security Service Statement, select I have read and agree to the Database Security Service Statement, and click Submit.
  7. On the displayed page, select a payment method.
    • Balance/Online payment
      Use your account balance to pay for your order. If the balance is insufficient, click Top Up to recharge your account.
      1. Select Balance.
      2. Click Pay.
    • Request Online Contract and Pay
      1. Choose Request Online Contract and Pay and click Create Contract.
      2. Enter the contract information and click Create Formal Contract.
  8. After you pay for your order, you can view the creation status of your instances.
