Help Center/ DataArts Studio/ User Guide/ DataArts Migration (Real-Time Jobs)/ Tutorials/ Configuring a Job for Synchronizing Data from MySQL to DMS for Kafka
Updated on 2025-09-09 GMT+08:00
Supported Source and Destination Database Versions
Table 1 Supported database versions
Source Database
MySQL database (5.6, 5.7, and 8.x)
Kafka cluster (2.7 and 3.x)
Database Account Permissions
Before you use DataArts Migration for data synchronization, ensure that the source and destination database accounts meet the requirements in the following table. The required account permissions vary depending on the synchronization task type.
Table 2 Database account permissions
Type
Required Permissions
Source database account
The source database account must have the following minimal permissions required for running SQL statements: SELECT, SHOW DATABASES, REPLICATION SLAVE and REPLICATION CLIENT.
GRANT SELECT, SHOW DATABASES, REPLICATION SLAVE, REPLICATION CLIENT ON *.* TO 'Username'@'%';
Destination database account
When ciphertext access is enabled for Kafka, the account must have the permissions to publish and subscribe to topics. In other scenarios, there are no special permission requirements.
  • You are advised to create independent database accounts for DataArts Migration task connections to prevent task failures caused by password modification.
  • After changing the account passwords for the source or destination databases, modify the connection information in Management Center as soon as possible to prevent automatic retries after a task failure. Automatic retries will lock the database accounts.
Supported Synchronization Objects
The following table lists the objects that can be synchronized using different links in DataArts Migration.
Table 3 Synchronization objects
Type
Note
  • DML and DDL can be synchronized.
  • Only MyISAM and InnoDB tables can be synchronized.
  • Views, foreign keys, stored procedures, triggers, functions, events, virtual columns, unique constraints, and unique indexes cannot be synchronized.
  • Foreign keys that contain reference operations such as CASCADE, SET NULL, and SET DEFAULT cannot be synchronized. These operations will cause the update or deletion of rows in parent tables and affect records in child tables. Also, operations related to child tables are not recorded in Binlogs.
Important Notes
In addition to the constraints on supported data sources and versions, connection account permissions, and synchronization objects, you also need to pay attention to the notes in the following table.
Table 4 Important notes
Type
Restriction
Database
  • The names of the source databases, tables, and fields cannot contain non-ASCII characters or the following characters: .<'>/\" (You are advised to use common characters to avoid a failure.)
  • During data synchronization, SASL_SSL authentication can be enabled only for DMS for Kafka that uses the default certificate. It cannot be enabled for other types of Kafka.
Usage
General:
  • During real-time synchronization, the IP addresses, ports, accounts, and passwords cannot be changed.
  • The source database cannot be restored.
  • Binlogs must be enabled for the source database and the value of binlog_row_image must be full.
  • It is recommended that MySQL binlogs be retained for more than three days. Binlogs cannot be forcibly cleared.
    When a job is restored after an exception or suspension, the recorded binlog location may expire. As a result, the job fails to be restored. It is important to monitor the duration of job exceptions or suspensions and the binlog retention period.
  • During real-time synchronization, the source MySQL database cannot be upgraded across major versions. Otherwise, data may become inconsistent or the synchronization task may fail (data, table structures, and keywords may cause compatibility changes after the cross-version upgrade). You are advised to create a synchronization task again if the source MySQL database is upgraded across major versions.
Full synchronization phase:
During task startup and full data synchronization, do not perform DDL operations on the source database. Otherwise, the task may fail.
Incremental synchronization phase:
During incremental synchronization of database and table shards, if DDL operations are performed on multiple table shards, multiple pieces of data will be synchronized to Kafka topics.
Extraction from the standby database:
Before extracting data from the standby database, ensure that a value can be returned after the SHOW MASTER STATUS command is executed on the standby database node. Otherwise, data jobs may be abnormal and data may be lost when the jobs are suspended and then resumed.
Troubleshooting:
If any problem occurs during task creation, startup, full synchronization, incremental synchronization, or completion, rectify the fault by referring to FAQs.
Other
Only DDL operations (for example, RENAME TABLE A TO B, in which B must be within the synchronization scope) can be performed to rename tables only if the renamed tables are within the synchronization scope.
This section uses real-time synchronization from RDS for MySQL to DMS for Kafka as an example to describe how to configure a real-time data migration job. Before that, ensure that you have read the instructions described in Performing a Check Before Using a Real-Time Job and completed all the preparations.
  1. Create a real-time migration job by following the instructions in Creating a Real-Time Migration Job and go to the job configuration page.
  2. Select the data connection type. Select MySQL for Source and DMS for Kafka for Destination.
    Figure 1 Selecting the data connection type
  3. Select a job type. The default migration type is Real-time. The migration scenarios include Entire DB and Database/Table partition.
    Figure 2 Setting the migration job type
    For details about synchronization scenarios, see Synchronization Scenarios.
  4. Configure network resources. Select the created MySQL and DMS for Kafka data connections and the migration resource group for which the network connection has been configured.
    Figure 3 Selecting data connections and a migration resource group
    If no data connection is available, click Create to go to the Manage Data Connections page of the Management Center console and click Create Data Connection to create a connection. For details, see Configuring DataArts Studio Data Connection Parameters.
    If no migration resource group is available, click Create to create one. For details, see Buying a DataArts Migration Resource Group Incremental Package.
  5. Check the network connectivity. After the data connections and migration resource group are configured, perform the following operations to check the connectivity between the data sources and the migration resource group.
  6. Configure source parameters.
    Select the databases and tables to be synchronized based on the following table.
    Table 5 Selecting the databases and tables to be synchronized
    Configuration Method
    Entire DB
    Select the MySQL databases and tables to be migrated.
    Figure 4 Selecting databases and tables
    Both databases and tables can be customized. You can select one database and one table, or multiple databases and tables.
    Database/Table shard
    Add a logical table.
    • Logical Table Name: Enter the name of the topic to be written to DMS for Kafka.
    • Source Database Filter: You can enter a regular expression to filter all the database shards from which data will be extracted and written to the destination Kafka topic.
    • Source Table Filter: You can enter a regular expression to filter all the table shards in the source database shard from which data will be extracted and written to the destination Kafka topic.
      Figure 5 Adding a logical table
    You can click Preview in the Operation column to preview an added logical table. When you preview a logical table, the more the source tables, the longer the waiting time.
    Figure 6 Previewing the logical table
  7. Configure destination parameters.
    Figure 7 Kafka destination parameters
    • Destination Topic Name Rule
      Configure the rule for mapping source MySQL database tables to destination Kafka topics.
      Table 6 Destination topic name rule
      Entire DB
      Configure the rule for mapping source MySQL database tables to destination Kafka topics. You can specify a fixed topic or use built-in variables to synchronize data from source tables to destination topics.
      The following built-in variables are available:
      • Source database name: #{source_db_name}
      • Source table name: #{source_table_name}
      If this parameter is not set, the logical table name configured for the source is used as the name of the destination topic by default.
    • Kafka Partition Synchronization Policy
      The following three policies are available for synchronizing source data to specified partitions of destination Kafka topics:
      • To partition 0
      • To different partitions based on the hash values of database names/table names
      • To different partitions based on the hash values of table primary keys
        If the source has no primary key, data is synchronized to partition 0 at the destination by default.
    • Database Operation to Be Synchronized
      One or more DDL and DML operations can be synchronized. If you do not select any operation, all operations are synchronized by default.
    • Data Format in Kafka
      Select the format of the data to be written to Kafka. Debezium JSON and Canal JSON are supported.
    • Partitions of New Topic
      If the destination Kafka does not have the corresponding topic, the topic automatically created by DataArts Migration has three partitions.
    • Destination Kafka Attributes
      You can add Kafka configuration items with the properties. prefix. The job automatically removes the prefix and transfers configuration items to the underlying Kafka client. For details about the parameters, see the configuration descriptions in Kafka documentation.
    • Advanced Settings
      You can add custom attributes in the Configure Task area to enable some advanced functions. For details about the parameters, see the following table.
      Figure 8 Adding custom attributes
      Table 7 Advanced parameters of the job for migrating data from MySQL to Kafka
      Type
      Default Value
      Unit
      source.server.timezone
      string
      Local time zone
      N/A
      Session time zone specified for connecting to the source database. The standard time zone format is supported, for example, UTC+08:00.
      source.convert.timestampWithServerTimeZone
      boolean
      true
      N/A
      Whether to convert the output timestamp data to data with the source time zone.
      source.convert.bit1AsInt
      boolean
      true
      N/A
      Whether to output bit1 data as int data
      sink.delivery-guarantee
      string
      at-least-once
      N/A
      Semantic assurance when Flink writes data to Kafka
      • at-least-once: At a checkpoint, the system waits for all data in the Kafka buffer to be confirmed by the Kafka producer. No message will be lost due to events that occur on the Kafka broker. However, duplicate messages may be generated when Flink is restarted because Flink processes old data again.
      • exactly-once: In this mode, the Kafka sink writes all data through the transactions submitted at a checkpoint. Therefore, if the consumer reads only submitted data, duplicate data will not be generated when Flink is restarted. However, data is visible only when a checkpoint is complete, so you need to adjust the checkpoint interval as needed.
  8. Update the mapping between the source table and destination table and check whether the mapping is correct.
    Table 8 Mapping between source and destination tables
    Entire DB
    You can change the names of mapped destination topics as needed. You can map one source topic to one destination topic or map multiple source topics to one destination topic.
    Figure 9 Mapping between the source and destination tables in the entire database migration scenario
    By default, the logical table name configured for the source is used as the name of the destination topic.
    Figure 10 Mapping between the source and destination tables in the database or table shard migration scenario
  9. Configure task parameters.
    Table 9 Task parameters
    Default Value
    Execution Memory
    Memory allocated for job execution, which automatically changes with the number of CPU cores
    8GB
    CPU Cores
    Value range: 2 to 32
    For each CPU core added, 4 GB execution memory and one concurrency are automatically added.
    2
    Maximum Concurrent Requests
    Maximum number of jobs that can be concurrently executed. This parameter does not need to be configured and automatically changes with the number of CPU cores.
    Auto Retry
    Whether to enable automatic retry upon a job failure
    No
    Maximum Retries
    This parameter is displayed when Auto Retry is set to Yes.
    Retry Interval (Seconds)
    120s
    Write Dirty Data
    Whether to record dirty data. By default, dirty data is not recorded. If there is a large amount of dirty data, the synchronization speed of the task is affected.
    • No: Dirty data is not recorded. This is the default value.
      Dirty data is not allowed. If dirty data is generated during the synchronization, the task fails and exits.
    • Yes: Dirty data is allowed, that is, dirty data does not affect task execution.
      When dirty data is allowed and its threshold is set:
      • If the generated dirty data is within the threshold, the synchronization task ignores the dirty data (that is, the dirty data is not written to the destination) and is executed normally.
      • If the generated dirty data exceeds the threshold, the synchronization task fails and exits.
        Criteria for determining dirty data: Dirty data is meaningless to services, is in an invalid format, or is generated when the synchronization task encounters an error. If an exception occurs when a piece of data is written to the destination, this piece of data is dirty data. Therefore, data that fails to be written is classified as dirty data.
        For example, if data of the VARCHAR type at the source is written to a destination column of the INT type, dirty data cannot be written to the migration destination due to improper conversion. When configuring a synchronization task, you can configure whether to write dirty data during the synchronization and configure the number of dirty data records (maximum number of error records allowed in a single partition) to ensure task running. That is, when the number of dirty data records exceeds the threshold, the task fails and exits.
    No
    Dirty Data Policy
    This parameter is displayed when Write Dirty Data is set to Yes. The following policies are supported:
    • Do not archive: Dirty data is only recorded in job logs, but not stored.
    • Archive to OBS: Dirty data is stored in OBS and printed in job logs.
    Do not archive
    Write Dirty Data Link
    This parameter is displayed when Dirty Data Policy is set to Archive to OBS.
    Only links to OBS support dirty data writes.
    N/A
    Dirty Data Directory
    OBS directory to which dirty data will be written
    N/A
    Dirty Data Threshold
    This parameter is only displayed when Write Dirty Data is set to Yes.
    You can set the dirty data threshold as required.
    • The dirty data threshold takes effect for each concurrency. For example, if the threshold is 100 and the concurrency is 3, the maximum number of dirty data records allowed by the job is 300.
    • Value -1 indicates that the number of dirty data records is not limited.
    100
    Custom attributes
    You can add custom attributes to modify some job parameters and enable some advanced functions. For details, see Job Performance Optimization.
    N/A
  10. Submit and run the job.
    After configuring the job, click Submit in the upper left corner to submit the job.
    Figure 11 Submitting the job
    After submitting the job, click Start on the job development page. In the displayed dialog box, set required parameters and click OK.
    Figure 12 Starting the job
    Table 10 Parameters for starting the job
    Offset Parameter
    • Incremental synchronization: Incremental data synchronization starts from a specified time point.
    • Full and incremental synchronization: All data is synchronized first, and then incremental data is synchronized in real time.
    Time
    This parameter must be set for incremental synchronization, and it specifies the start time of incremental synchronization.
    If you set a time that is earlier than the earliest binlog time, the latest log time is used.
  11. Monitor the job.
    On the job development page, click Monitor to go to the Job Monitoring page. You can view the status and log of the job, and configure alarm rules for the job. For details, see Real-Time Migration Job O&M.
    Figure 13 Monitoring the job
If the synchronization speed is too slow, rectify the fault by referring to Job Performance Optimization.
