Configuring a Job for Synchronizing Data from MySQL to DWS
Supported Source and Destination Database Versions
| Source Database | Destination Database |
| MySQL database (5.6, 5.7, and 8.x) | DWS cluster of version 8.1.3, 8.2.0, or a later version, except DWS 3.0 |
Database Account Permissions
Before you use DataArts Migration for data synchronization, ensure that the source and destination database accounts meet the requirements in the following table. Different types of synchronization tasks require different permissions. For details, see Table 2.
| Type | Required Permissions |
| Source database account | The source database account must have the following minimal permissions required for running SQL statements: SELECT, SHOW DATABASES, REPLICATION SLAVE and REPLICATION CLIENT. GRANT SELECT, SHOW DATABASES, REPLICATION SLAVE, REPLICATION CLIENT ON *.* TO 'Username'@'Resource group network segment', 'Username'@'IP address of the CDM cluster as an agent'; |
| Destination database account | The destination database account must have the following permissions for each table in the database: INSERT, SELECT, UPDATE, DELETE, CONNECT, and CREATE. |
- You are advised to create independent database accounts for DataArts Migration task connections to prevent task failures caused by password modification.
- After changing the account passwords for the source or destination databases, modify the connection information in Management Center as soon as possible to prevent automatic retries after a task failure. Automatic retries will lock the database accounts.
Supported Synchronization Objects
Table 3 lists the objects that can be synchronized in different scenarios.
| Type | Note |
| Synchronization objects |
Notes
In addition to the constraints on supported data sources and versions, connection account permissions, and synchronization objects, you also need to pay attention to the notes in Table 4.
| Type | Restriction |
| Database |
| Usage | General:
Full synchronization phase: During task startup and full data synchronization, do not perform DDL operations on the source database. Otherwise, the task may fail. Incremental synchronization phase:
Extraction from the standby database: Before extracting data from the standby database, ensure that a value can be returned after the SHOW MASTER STATUS command is executed on the standby database node. Otherwise, data jobs may be abnormal and data may be lost when the jobs are suspended and then resumed. Troubleshooting: If any problem occurs during task creation, startup, full synchronization, incremental synchronization, or completion, rectify the fault by referring to FAQs. |
| Other |
This section uses real-time synchronization from RDS for MySQL to DWS as an example to describe how to configure a real-time data migration job. Before that, ensure that you have read the instructions described in Performing a Check Before Using a Real-Time Job and completed all the preparations.
- Create a real-time migration job by following the instructions in Creating a Real-Time Migration Job and go to the job configuration page.
- Select the data connection type. Select MySQL for Source and DWS for Destination. Figure 1 Selecting the data connection type
- Select a job type. The default migration type is Real-time. The migration scenarios include Entire DB and Database/Table partition. Figure 2 Setting the migration job type
- Configure network resources. Select the created MySQL and DWS data connections and the migration resource group for which the network connection has been configured. Figure 3 Selecting data connections and a migration resource group
If no data connection is available, click Create to go to the Manage Data Connections page of the Management Center console and click Create Data Connection to create a connection. For details, see Configuring DataArts Studio Data Connection Parameters.
If no migration resource group is available, click Create to create one. For details, see Buying a DataArts Migration Resource Group Incremental Package.
- Check the network connectivity. After the data connections and migration resource group are configured, perform the following operations to check the connectivity between the data sources and the migration resource group.
- Click Source Configuration. The system will test the connectivity of the entire migration job.
- Click Test in the source and destination and migration resource group.
If the network connectivity is abnormal, see How Do I Troubleshoot a Network Disconnection Between the Data Source and Resource Group?
- Configure source parameters.
Select the databases and tables to be synchronized based on the following table.
Table 5 Selecting the databases and tables to be synchronized Scenario
Configuration
Entire DB
- Select synchronization objects.
- Table-level synchronization: Synchronize multiple tables in multiple databases of a MySQL instance.
- Database-level synchronization: Synchronize all tables in multiple databases of a MySQL instance.
- Select the MySQL databases and tables to be migrated. Figure 4 Selecting databases and tables
Both databases and tables can be customized. You can select one database and one table, or multiple databases and tables.
Add a logical table.- Logical Table Name: Enter the name of the table to be written to DWS.
- Source Database Filter: You can enter a regular expression to filter all the database shards to be written to the destination DWS aggregation table.
- Source Table Filter: You can enter a regular expression to filter all the table shards in the source database shard to be written to the destination DWS aggregation table.
When synchronizing database and table shards, ensure that at least one database table connected by each connection meets the configured filter criteria. Otherwise, the synchronization may fail.
Figure 5 Adding a logical table
You can click Preview in the Operation column to preview an added logical table. When you preview a logical table, the more the source tables, the longer the waiting time.
Figure 6 Previewing a logical table
- Configure destination parameters.
- Set Database and Table Matching Policy.
For details about the matching policy between source and destination databases and tables in each synchronization scenario, see the following table.
Table 6 Database and table matching policy Synchronization Scenario
Configuration Method
Entire DB
- Schema matching policy
- Same name as the source database: Data will be synchronized to the DWS schema with the same name as the source MySQL database.
- Custom: Data will be synchronized to the DWS schema you specify.
- Table matching policy
- Same name as the source table: Data will be synchronized to the DWS table with the same name as the source MySQL table.
- Custom: Data will be synchronized to the DWS table you specify. Figure 7 Database and table matching policy in the entire database migration scenario
NOTE:When you customize a matching policy, you can use built-in variables #{source_db_name} and #{source_table_name} to identify the source database name and table name. The table matching policy must contain #{source_table_name}.
Database/Table shard
- Destination Database Name: Data will be synchronized to the specified DWS schema.
- Table Matching Policy: By default, the value is the same as the name of the logical table entered in the source configuration.
Figure 8 Database and table matching policy in the sharding scenario
- Configure DWS parameters.
For details, see the following table.
Figure 9 DWS parameters
Table 7 DWS parameters Parameter
Default Value
Unit
Write Mode
UPSERT MODE
N/A
- UPSERT MODE: batch update
- COPY MODE: DWS-dedicated high-performance batch import
Maximum Data Volume for Batch Write
50000
Count
Number of data records written to DWS in a batch. You can adjust the value based on the table data size and job memory usage.
Scheduled Batch Write Interval
3
Second
Interval at which data is written to DWS
Advanced Settings
N/A
N/A
You can configure parameters to enable some advanced functions.
Click View and Edit under Advanced Settings. In the displayed Configure Global Table Attribute dialog box, set the following parameters:
- Orientation: storage mode of the data in the automatically created table. You can select ROW or COLUMN.
- Compression Level: This parameter is displayed when Orientation is set to COLUMN. It indicates the version of the column store.
The following formats are supported:
- DEFAULT: colversion is not set. The DWS default configuration is used.
- 1.0: colversion is 1.0. It is for DWS clusters of version 8.1.0 or earlier.
- 2.0: colversion is 2.0. It is for DWS clusters of version 8.1.1 or later.
- 3.0: colversion is 3.0. It is for version 9.0.X or later. In this version, storage and compute are decoupled. By default, column-store tables will be created, and the storage mode configuration is not applied.
- isCompress: This parameter is displayed when Storage Mode is Column-based. It specifies whether to compress data in the automatically created table.
- Extend char length: During automatic creation of a destination table, the length of a character field in the destination table is four times that of the corresponding field in the source table. If the encoding types of the source and destination databases are different, and the character fields in the source and destination tables are the same, errors may occur during data migration due to insufficient length. This option is selected by default.
- Use non-null constraints: If you select the NOT NULL constraint during automatic creation of a destination table, keep the NOT NULL constraints of the source and destination tables consistent. This option is selected by default.
- Custom Attribute: You can configure some functions using parameters. For details about the parameters, see the table that lists DWS advanced configurations.
Table 8 DWS advanced parameters Parameter
Type
Default Value
Unit
sink.buffer-flush.max-size
int
512
MB
Maximum number of bytes in each batch of data written to DWS. You can adjust the value based on the memory and data size configured for the job.
sink.keyby.enable
boolean
true
N/A
Whether to enable data distribution. If this function is enabled in multi-concurrency scenarios, data can be distributed to different processes based on specific rules and written to the destination, which improves the write performance.
sink.keyby.mode
string
table
N/A
Data distribution mode. The following modes are available:
- pk: Data is distributed by primary key value.
- table: Data is distributed by table name. NOTE:
- In multi-concurrency scenarios, if DDL is enabled, data can be distributed only by table name. Otherwise, data may be inconsistent.
- If there is no DDL, you can select pk, which improves the write performance in multi-concurrency scenarios.
sink.field.name.case-sensitive
boolean
true
N/A
Whether to enable case sensitivity for data synchronization. If this function is enabled, the database names, table names, and field names are case sensitive during data synchronization.
sink.verify.column-number
boolean
false
N/A
Whether to verify the number of data columns. By default, the link synchronizes data in the same-name mapping mode. The system does not check whether all columns are synchronized.
If this function is enabled and the number of columns at the source is different from that at the destination, the system determines that data is inconsistent. As a result, the job is abnormal.
sink.server.timezone
string
Local time zone
N/A
Session time zone specified for connecting to the destination database. The standard time zone format is supported, for example, UTC+08:00.
logical.delete.enabled
boolean
false
N/A
Whether to enable logical deletion. If this function is enabled, the destination must contain the deletion flag column. When data is deleted from the source database, the corresponding data in the destination database will not be deleted. Instead, the deletion flag column is set to true, indicating that the data is not contained at the source.
logical.delete.column
string
logical_is_deleted
N/A
Name of the logical deletion column. The default value is logical_is_deleted. You can customize the value.
sink.ddl.isCreateIndex
string
true
N/A
Whether to synchronize source indexes. If this function is enabled, source indexes will be synchronized during automatic table creation.
exclude.extend.char.length.field.type
string
N/A
N/A
Types of fields that do not need to be extended. Use commas (,) to separate field types.
NOTE:Ensure that Extend Character Field Length in the DWS parameters is selected so that this parameter can take effect.
exclude.extend.char.length.field.name
string
N/A
N/A
Names of fields that do not need to be extended. Use commas (,) to separate field names.
- Refresh and check the mapping between the source and destination tables. In addition, you can modify table attributes, add additional fields, and use the automatic table creation capability to create tables in the destination DWS database. Figure 10 Mapping between source and destination tables
- Edit additional fields: Click Additional Field in the Operation column to add custom fields to the destination DWS table. For a new table, you can add additional fields to the existing fields in the source table. You can customize the field name, select the field type, and enter the field value.
- Field Name: name of the new field in the destination DWS table
- Field Type: type of the new field in the destination DWS table
- (Optional) Field Type Length: length of the new field type in the destination DWS table
- Field Value: Value source of the new field in the destination DWS table
Table 9 Additional field value obtaining mode Type
Example
Constant
Digits, letters, and special characters are supported. Color emoticons may cause a job submission failure.
Built-in variable
- Source host IP address: source.host
- Source schema name: source.schema
- Source table name: source.table
- Destination schema name: target.schema
- Destination table name: target.table
Source table field
Any field in the source table
Do not change the name of the source table field when the job is running. Otherwise, the job may be abnormal.
UDF
- substring(#col, pos[, len]): obtains a substring of a specified length from the source column name. The substring range is [pos, pos+len).
- date_format(#col, time_format[, src_tz, dst_tz]): formats the source column name based on a specified time format. The time zone can be converted using src_tz and dst_tz.
- now([tz]): obtains the current time in a specified time zone.
- if(cond_exp, str1, str2): returns str1 if the condition expression cond_exp is met and returns str2 otherwise.
- concat(#col[, #str, ...]): concatenates multiple parameters, including source columns and strings.
- from_unixtime(#col[, time_format]): formats a Unix timestamp based on a specified time format.
- unix_timestamp(#col[, precision, time_format]): converts a time into a Unix timestamp of a specified time format and precision. time_format must be the same as that in the source data.
- Automatic table creation: Click Auto Table Creation to automatically create tables in the destination database based on the configured mapping policy. After the tables are created, Existing table is displayed for them. Figure 11 Automatic table creation
- DataArts Migration supports only automatic table creation. You need to manually create databases and schemas at the destination before using this function.
- For details about the field type mapping for automatic table creation, see Field Type Mapping.
- Database-level synchronization does not support automatic table creation. You can create tables through table synchronization, switch to database synchronization, and set Create Table in the DDL policy to Normal processing to enable automatic table creation.
- Configure DDL message processing rules.
Real-time migration jobs can synchronize data manipulation language (DML) operations, such as adding, deleting, and modifying data, as well as some table structure changes using the data definition language (DDL). You can set the processing policy for a DDL operation to Normal processing, Ignore, or Error.
- Normal processing: When a DDL operation on the source database or table is detected, the operation is automatically synchronized to the destination.
- Ignore: When a DDL operation on the source database or table is detected, the operation is ignored and not synchronized to the destination.
- Error: When a DDL operation on the source database or table is detected, the migration job throws an exception. Figure 12 DDL configuration
- Configure task parameters.
Table 10 Task parameters Parameter
Default Value
Execution Memory
Memory allocated for job execution, which automatically changes with the number of CPU cores
8GB
CPU Cores
Value range: 2 to 32
For each CPU core added, 4 GB execution memory and one concurrency are automatically added.
2
Maximum Concurrent Requests
Maximum number of jobs that can be concurrently executed. This parameter does not need to be configured and automatically changes with the number of CPU cores.
Auto Retry
Whether to enable automatic retry upon a job failure
No
Maximum Retries
This parameter is displayed when Auto Retry is set to Yes.
Retry Interval (Seconds)
120s
Write Dirty Data
Whether to record dirty data. By default, dirty data is not recorded. If there is a large amount of dirty data, the synchronization speed of the task is affected.
- No: Dirty data is not recorded. This is the default value.
Dirty data is not allowed. If dirty data is generated during the synchronization, the task fails and exits.
- Yes: Dirty data is allowed, that is, dirty data does not affect task execution. When dirty data is allowed and its threshold is set:
- If the generated dirty data is within the threshold, the synchronization task ignores the dirty data (that is, the dirty data is not written to the destination) and is executed normally.
- If the generated dirty data exceeds the threshold, the synchronization task fails and exits. NOTE:
Criteria for determining dirty data: Dirty data is meaningless to services, is in an invalid format, or is generated when the synchronization task encounters an error. If an exception occurs when a piece of data is written to the destination, this piece of data is dirty data. Therefore, data that fails to be written is classified as dirty data.
For example, if data of the VARCHAR type at the source is written to a destination column of the INT type, dirty data cannot be written to the migration destination due to improper conversion. When configuring a synchronization task, you can configure whether to write dirty data during the synchronization and configure the number of dirty data records (maximum number of error records allowed in a single partition) to ensure task running. That is, when the number of dirty data records exceeds the threshold, the task fails and exits.
No
Dirty Data Policy
This parameter is displayed when Write Dirty Data is set to Yes. The following policies are supported:
- Do not archive: Dirty data is only recorded in job logs, but not stored.
- Archive to OBS: Dirty data is stored in OBS and printed in job logs.
Do not archive
Write Dirty Data Link
This parameter is displayed when Dirty Data Policy is set to Archive to OBS.
Only links to OBS support dirty data writes.
N/A
Dirty Data Directory
OBS directory to which dirty data will be written
N/A
Dirty Data Threshold
This parameter is only displayed when Write Dirty Data is set to Yes.
You can set the dirty data threshold as required.
NOTE:- The dirty data threshold takes effect for each concurrency. For example, if the threshold is 100 and the concurrency is 3, the maximum number of dirty data records allowed by the job is 300.
- Value -1 indicates that the number of dirty data records is not limited.
100
Enable Heartbeat Tables
Whether to enable heartbeat tables. It is disabled by default.
If heartbeat tables are enabled, the real-time migration job creates a heartbeat table at the source (if there are no such tables). Then data will be periodically updated to the table during job execution.
- Ensure that the data source instance is writable.
- Ensure that the account has the permissions to create heartbeat tables, write data to heartbeat tables, and extract data from heartbeat tables.
No
Schema/Tablespace
Schema or tablespace of the heartbeat table
test_database
Table Name
Heartbeat table name
If the table does not exist, the real-time migration job will automatically create it. Ensure that the account used for the data source connection has the permission to create tables.
You can manually create a table. For details about the table format, see Heartbeat Table Format.
test_hearbeat_table
Heartbeat Generation Interval
Interval at which the real-time migration job generates and writes heartbeat data to the heartbeat table, in seconds
10
Output Statistics
Whether to output statistics. It is disabled by default.
If output statistics are enabled, the real-time migration job outputs the write statistics of each batch to a specified topic.
Data of this topic can be consumed for timeliness analysis and data statistics.
For details about the statistics format, see Statistical Information Format.
No
Output Policy
Statistics output policy. Statistics can be output to DMS for Kafka or logs.
Output to Kafka
Output Connection
The connection used to write statistics
NOTE:- If no data connection is available, click Create to go to the Manage Data Connections page of the Management Center console and click Create Data Connection to create a connection. For details, see Configuring DataArts Studio Data Connection Parameters.
- Ensure that the data source corresponding to the connection can communicate with the resource group. Click Test Connectivity to check the connectivity between the data source and the resource group. If the network connectivity is abnormal, rectify the issue by referring to What Do I Do If the Network Between the Data Source and the Migration Resource Group Is Disconnected?
Output Topic
The topic that statistics will be written to. Only one topic is allowed.
Throw Exception Upon Failure
Whether to throw an exception upon a statistics output failure
No
Add Custom Attribute
You can add custom attributes to modify some job parameters and enable some advanced functions. For details, see Job Performance Optimization.
N/A
- Submit and run the job.
After configuring the job, click Submit in the upper left corner to submit the job.
Figure 13 Submitting the job
After submitting the job, click Start on the job development page. In the displayed dialog box, set required parameters and click OK.
Figure 14 Starting the job
Table 11 Parameters for starting the job Parameter
Offset Parameter
- Incremental synchronization: Incremental data synchronization starts from a specified time point.
- Full and incremental synchronization: All data is synchronized first, and then incremental data is synchronized in real time.
Time
This parameter must be set for incremental synchronization, and it specifies the start time of incremental synchronization.
NOTE:If you set a time that is earlier than the earliest binlog time, the latest log time is used.
- Monitor the job.
On the job development page, click Monitor to go to the Job Monitoring page. You can view the status and log of the job, and configure alarm rules for the job. For details, see Real-Time Migration Job O&M.
Figure 15 Monitoring the job
If the synchronization speed is too slow, rectify the fault by referring to Job Performance Optimization.
