Monitoring Metrics Supported by DataArts DataService
Function
Cloud Eye monitors the running status of cloud services and usage of each metric, and creates alarm rules for monitoring metrics.
After you create an exclusive cluster and enable Cloud Eye monitoring, Cloud Eye automatically associates with the exclusive cluster metrics to help you obtain the performance metrics of the exclusive cluster in real time and accurately monitor its running status.
- This section describes the exclusive cluster metrics that can be monitored by Cloud Eye as well as their namespaces and dimensions.
- If you want Cloud Eye to monitor an exclusive cluster, enable Cloud Eye monitoring first. For details, see Enabling Cloud Eye Monitoring.
- For details about exclusive cluster monitoring metrics, see Viewing Monitoring Metrics of DataArts DataService.
- For details about how to set alarm rules, see Creating an Alarm Rule for DataArts DataService.
You have obtained required Cloud Eye permissions.
Namespace
SYS.DLM
Monitoring Metrics
Table 1 lists the monitoring metrics for exclusive clusters.
Metric ID | Metric Name | Metric Description | Value Range | Unit | Conversion Rule | Dimension | Monitoring Period (Raw Data) |
average_latency | Average Request Latency | Average latency from the time when a node receives a command to the time when the node responds | >=0 | ms | Decimal | dlm_instance_id | 1 minute |
max_latency | Maximum Latency | Maximum latency from the time when a node receives a command to the time when the node responds | >=0 | ms | Decimal | dlm_instance_id | 1 minute |
api_calls | API Calls | Number of calls made to an API | >=0 | Count | Decimal | dlm_instance_id | 1 minute |
error_5xx | 5xx Errors | Number of 5xx errors returned for API call requests | >=0 | Count | Decimal | dlm_instance_id | 1 minute |
error_4xx | 4xx Errors | Number of 4xx errors returned for API call requests | >=0 | Count | Decimal | dlm_instance_id | 1 minute |
health_check | Health Check | Health check of the service | >=0 | Count | Decimal | dlm_instance_id | 1 minute |
cpu_usage | CPU Usage | Average CPU usage of all resource instance nodes | 0% to 100% | % | N/A | dlm_instance_id | 1 minute |
memory_usage | Memory usage | Average memory usage of all resource instance nodes | 0% to 100% | % | N/A | dlm_instance_id | 1 minute |
network_connections | Network Connections | Total number of network connections of all resource instance nodes | >=0 | Count | Decimal | dlm_instance_id | 1 minute |
Dimension
Key | Value |
dlm_instance_id | ID of a dedicated cluster For details about how to obtain the value, see "Querying the Cluster Overview Information List" "Querying the Cluster Overview Information List" "Querying the Cluster Overview Information List" DataArts Studio User Guide (for Huawei Cloud Stack 8.6.1) > API Reference. Obtain the value from the interface for querying the cluster overview information list. |
