Updated on 2025-09-09 GMT+08:00
Creating an Alarm Rule
Creating an alarm rule for a real-time migration job allows you to customize the monitored objects and notification policies so that you can closely monitor the job.
An alarm rule includes the alarm rule name, monitored object, metric, threshold, monitoring interval, and whether to send notifications. This section describes how to set an alarm rule for a real-time processing migration job.
Enabling One-Click Alarm Reporting
One-click monitoring allows you to quickly and easily enable or disable monitoring of common events and metrics for DataArts Studio. For details about how to enable one-click alarm reporting for DataArts Studio, see One-Click Monitoring.
Configuring Alarms for All Resources
You can set alarm policies for monitoring metrics of real-time processing migration jobs. When a metric triggers the threshold in the alarm policy for multiple times in a specified period, you will be notified. For details, see Creating an Alarm Rule.
Set Alarm Type to Metric and DataArts Studio - DataArts Studio Resources for Cloud product.
Setting an Alarm Rule for a Real-Time Processing Migration Job
  1. Log in to the DataArts Studio console by following the instructions in Accessing the DataArts Studio Instance Console.
  2. On the DataArts Studio console, locate a workspace and click DataArts Factory.
  3. In the left navigation pane of DataArts Factory, choose Monitoring > Job Monitoring.
  4. On the Real-Time Migration Jobs page, click a job name.
  5. In the slide-out panel, click the Monitoring information tab, and then click Create Alarm Rule to go to the Cloud Eye console and create an alarm rule for the job.
    Figure 1 Creating an alarm rule
  6. After setting the parameters, click Create. When an alarm that meets the rule is generated, the system automatically sends a notification.
    For more information about monitoring and alarms, see the Cloud Eye User Guide.
