Using an Enterprise Router to Enable Network Communications for the Same Region but Different Tenants
Before configuring a real-time synchronization task, ensure that the source and destination databases can communicate with the real-time compute resource group that you want to use to run the real-time synchronization task. You can choose a proper network solution based on the network environments of the databases.
This section describes how to enable communications between a database deployed on Huawei Cloud and a migration resource group in the same region as but of different tenants from the database using an enterprise router.
Notes and Constraints
- The migration resource group uses a private network segment that cannot overlap with the network segment of the data source. Otherwise, the network cannot be connected.
- The migration resource group does not have a public network segment and can only connect to the private network of the data source.
- You have purchased a migration resource group. For details, see Buying a DataArts Migration Resource Group Incremental Package.
- You have purchased and configured an enterprise router to enable communications between the data source VPC and a VPC of the current tenant. For how to enable and configure an enterprise router, see Using an Enterprise Router to Enable Communications Between VPCs in the Same Region and Sharing Enterprise Routers.
Preparations
Obtain the network segments of the related objects (including the data source, tenant VPC, and migration resource group).
| Resource | Description | Example Private Network Segment |
| Data source network segment | VPC to which the Huawei Cloud data source belongs. The method of viewing the VPC varies depending on the data source. For details, see the official documentation of the corresponding data source. | 192.168.0.0/24 |
| Tenant VPC | Used for the communications between the data source and migration resource group. In this solution, a VPC of the current tenant configured in the enterprise router is used. To obtain the VPC, perform the following operations: Log in to the Enterprise Router console as the current tenant. In the navigation pane on the left, choose Enterprise Router > Enterprise Routers. In the router list, locate a router and click Manage Attachment. On the displayed Attachments page, find the VPC of the current tenant, which can be used as the tenant VPC. Figure 2 Viewing attachments of an enterprise router Figure 3 Determining the tenant VPC | VPC: 10.186.0.0/19 |
| Migration resource group VPC | VPC to which the real-time computing resource group belongs. The migration resource group is created under the resource tenant of the user account and uses the VPC network segment of the resource tenant. To obtain the VPC, perform the following operations: Log in to the DataArts Studio console, access an instance, and click the Resources tab. On the Real-Time Resources page, expand the target migration resource group to view its VPC network segment. Figure 4 Obtaining the migration resource group network segment | 172.16.0.0/19 |
Network Configuration Process
- Configure rules for the security group to which the Huawei Cloud database belongs.
Add an inbound rule for the security group of the Huawei Cloud database to allow the VPC network segment (for example, 172.16.0.0/19) of the resource group to access the database listening port.
To add a security group rule, perform the following steps: Go to the data source service page, access the user cluster, locate the network information, and click the security group. On the displayed security group editing page, add an inbound rule. The following is an example of how to allow access from the migration resource group.
Priority Policy Type Protocol Port Source Address 1 Allow IPv4 All protocols IP address: migration resource group network segment
The ports used by different data sources vary. Configure the ports for security group rules by referring to Which Ports Must Be Allowed by the Data Source Security Group So That DataArts Migration Can Access the Data Source?
- Add a route to the network of the database on Huawei Cloud.
Add a route to the route table of the VPC subnet to which the Huawei Cloud database belongs. Set the destination to the VPC network segment of the migration resource group (for example, 172.16.0.0/19), and set the next hop to the enterprise router you have configured.
- Log in to the VPC console as the data source tenant. In the navigation pane on the left, choose Virtual Private Cloud > Subnets. Locate the subnet of data source and click the route table name to go to the configuration page. Figure 5 Obtaining the data source route table
- On the displayed page, click the Summary tab and then Add Route. In the displayed dialog box, set Destination to the VPC network segment of the migration resource group (for example, 172.16.0.0/19) and Next Hop to the enterprise router you have configured. Figure 6 Adding a route to the route table of the data source
- Add a route to the enterprise router.
Log in to the Enterprise Router console. In the navigation pane on the left, choose Enterprise Router > Enterprise Routers. In the router list, locate the target router and click Manage Route Table.
Figure 7 Viewing the route tables of an enterprise router
Click the Routes tab and then Create Route. In the displayed dialog box, set Destination to the VPC network segment of the real-time migration resource group (for example, 172.16.0.0/19), Attachment Type to VPC, and Next Hop to the connection corresponding to the tenant VPC.
Figure 8 Creating a route
- Create a real-time network connection.
To connect the tenant VPC to the real-time migration resource group VPC, you can create a VPC peering connection between the two VPCs using the resource management function provided of DataArts Studio.
Figure 9 Creating a network connection
On the Real-Time Network Connections tab page, click Create. In the displayed Create Network Connection dialog box, set required parameters.
Table 2 Parameters for creating a network connection Parameter
Connection Name
Name of the network connection
Only letters, digits, and underscores (_) are allowed.
Resource Group
Migration resource group that can communicate with the specified VPC.
If you do not select a migration resource group, you can bind migration resource groups to the connection after the connection is created by clicking More in the Operation column and selecting Bind Resource Group.
VPC
VPC that can communicate with the migration resource group
In this solution, the migration resource group network segment and the tenant VPC are connected through a VPC peering connection. Therefore, you must select a tenant VPC (for example, 10.186.0.0/19).
Subnet
Subnet of the tenant VPC, for example, 10.186.0.0/24
Routing Table
Routing table associated with the subnet. When the connection is bound to a migration resource group, routing information of the migration resource group is added to the routing table. You do not need to set this parameter.
When the connection is bound to a migration resource group, a route to the migration resource group VPC network segment is added to the routing table. The route connects the migration resource group network segment to the tenant VPC.
- Add a route to the data source network segment for the real-time network connection (VPC peering connection).
Locate the real-time network connection created in step 4, click More in the Operation column, and select Add Route. In the displayed dialog box, enter the network segment of the VPC subnet of the Huawei Cloud database, for example, 192.168.0.0/24.
Figure 10 Adding route 1
Figure 11 Adding route 2
- (Optional) For MRS data sources, perform the following extra operations to enable network communications:
After creating a real-time network connection and binding it to a migration resource group, click More in the Operation column and select Modify Host Information. In the displayed dialog box, enter the IP addresses and domain names of all nodes in the MRS cluster as prompted.
Figure 12 Modifying host information
To obtain the IP addresses and domain names of the nodes in an MRS cluster, perform the following steps:
- Open the MRS page, access the MRS cluster, click the Nodes tab, and expand all node groups to view the IP address and name (domain name) of each node.
Add the IP addresses (1 in the figure) and domain names (2 in the figure) of all nodes and separate them by pressing Enter.
Figure 13 Obtaining the IP addresses and domain names of the nodes in the MRS cluster
- Log in to an MRS cluster node by referring to Logging In to an MRS Cluster Node and run the cat /etc/hosts command to list the IP addresses and domain names of all nodes.
- Test the network connectivity.
In a DataArts Studio workspace, create a data connection and a real-time migration job, and select the corresponding data connection and migration resource group to test the connectivity. For details, see Creating a Real-Time Migration Job.
