Developing a Real-Time Processing Single-Task DLI Spark Job
A single-task real-time processing DLI Spark job has been created. For details, see Creating a Job.
Configuring a DLI Spark job
Parameter |
Mandatory |
Description |
Job Name |
Yes |
Enter the DLI Spark job name. The job name can contain 1 to 64 characters. Only letters, digits, hyphens (-), and underscores (_) are allowed. |
DLI Queue |
Yes |
Select a DLI queue. |
Spark Version |
No |
Job Type |
No |
Type of the Spark image used by the job. The following options are available:
Job Running Resource |
No |
Major Job Class |
No |
Java/Scala main class of the job |
Spark program resource package |
Yes |
Resource package on which the Spark program depends |
Resource Type |
Yes |
DLI program package: The resource package file will not be uploaded to the DLI resource management system before the job is executed. OBS path: The resource package file will not be uploaded to DLI resource management system before the job is executed. The OBS path where the file is located is part of the message body for starting the job. This type is recommended. |
Group |
No |
This parameter is required when Resource Type is set to DLI program package. A Spark program resource package is uploaded to a specified group. The main JAR package and dependency package are uploaded to the same group.
Major-Class Entry Parameters |
No |
Press Enter to separate parameters. |
No |
Enter parameters in key=value format and separate parameters by pressing Enter. |
Module Name |
No |
Select one or more module names. |
Metadata Access |
No |
Whether metadata can be accessed To access the OBS table created by the DLI SQL job in the DLI Spark job, enable metadata access. |
Parameter |
Mandatory |
Description |
Job Status Polling Interval (s) |
Yes |
Set the interval at which the system checks whether the job is complete. The interval can range from 30s to 60s, or 120s, 180s, 240s, or 300s. During job execution, the system checks the job status at the configured interval. |
Maximum Wait Time |
Yes |
Set the timeout interval for the job. If the job is not complete within the timeout interval and retry is enabled, the job will be executed again.
If the job is in starting state and fails to start, it will fail upon timeout. |
Retry upon Failure |
No |
Whether to re-execute a node if it fails to be executed.
After setting the parameters, click Save and submit the job.
Click Start to run the job.
Configuring Basic Job Information
Parameter |
Description |
Owner |
An owner configured during job creation is automatically matched. This parameter value can be modified. |
Executor |
This parameter is available when Scheduling Identities is set to Yes. User that executes the job. When you enter an executor, the job is executed by the executor. If the executor is left unspecified, the job is executed by the user who submitted the job for startup.
You can configure execution users only after you apply for the whitelist membership. To enable it, contact customer service or technical support. |
Job Agency |
This parameter is available when Scheduling Identities is set to Yes. After an agency is configured, the job interacts with other services as an agency during job execution. |
Priority |
Priority configured during job creation is automatically matched. This parameter value can be modified. |
Execution Timeout |
Timeout of the job instance. If this parameter is set to 0 or is not set, this parameter does not take effect. If the notification function is enabled for the job and the execution time of the job instance exceeds the preset value, the system sends a specified notification, and the job keeps running. |
Exclude Waiting Time from Instance Timeout Duration |
Whether to exclude the wait time from the instance execution timeout duration If you select this option, the time to wait before an instance starts running is excluded from the timeout duration. You can modify this setting in Default Configuration > Exclude Waiting Time from Instance Timeout Duration. If you do not select this option, the time to wait before an instance starts running is included in the timeout duration. |
Custom Parameter |
Set the name and value of the parameter. |
Job Tag |
Configure job tags to manage jobs by category. Click Add to add a tag to the job. You can also select a tag configured in Managing Job Tags. |
Job Description |
Description of the job |
Configuring job parameters
Click Parameter Setup on the right of the editor and set the parameters described in Table 4.
Module |
Description |
Variables |
Add |
Click Add and enter the variable parameter name and parameter value in the text boxes.
After the parameter is configured, it is referenced in the format of ${Parameter name} in the job. |
Edit Parameter Expression |
Click |
Modifying a Job |
Change the parameter name or value in the corresponding text boxes. |
Mask |
If the parameter value is a key, click |
Delete |
Click |
Constant Parameter |
Add |
Click Add and enter the constant parameter name and parameter value in the text boxes.
Click |
Modifying a Job |
Modify the parameter name and parameter value in text boxes and save the modifications. |
Delete |
Click |
Workspace Environment Variables |
View the variables and constants that have been configured in the workspace. |
Click the Parameter Preview tab and configure the parameters listed in Table 5.
Module |
Description |
Current Time |
This parameter is displayed only when Scheduling Type is set to Run once. The default value is the current time. |
Event Triggering Time |
This parameter is displayed only when Scheduling Type is set to Event-based. The default value is the time when an event is triggered. |
Scheduling Period |
This parameter is displayed only when Scheduling Type is set to Run periodically. The default value is the scheduling period. |
Start Time |
This parameter is displayed only when Scheduling Type is set to Run periodically. The value is the configured job execution time. |
Start Time |
This parameter is displayed only when Scheduling Type is set to Run periodically. The value is the time when the periodic job scheduling starts. |
Subsequent Instances |
Number of job instances scheduled.
In Parameter Preview, if a job parameter has a syntax error, the system displays a message.
If a parameter depends on the data generated during job execution, such data cannot be simulated and displayed in Parameter Preview.
