Developing a Real-Time Processing Single-Task MRS Flink SQL Job
This section describes how to develop and configure a job.
For details about how to develop a real-time processing Flink SQL job in single-task mode, see sections Developing an SQL Script, Configuring Job Parameters, Saving and Running the Job, and Templates.
- You have created a job by referring to Creating a Job.
- You have locked the job. Otherwise, you must click Lock so that you can develop the job. A job you create or import is locked by you by default. For details, see the lock function.
- Log in to the DataArts Studio console by following the instructions in Accessing the DataArts Studio Instance Console.
- On the DataArts Studio console, locate a workspace and click DataArts Factory.
- In the left navigation pane of DataArts Factory, choose .
- In the job directory, double-click the name of a single-task job to access the job development page.
- On the right of the SQL editor, click Basic Info to configure basic information of the job. Table 1 provides the basic information about the single-task MRS Flink SQL job.
Table 1 Basic job information Parameter
Owner
An owner configured during job creation is automatically matched. This parameter value can be modified.
Job Agency
This parameter is available when Scheduling Identities is set to Yes.
After an agency is configured, the job interacts with other services as an agency during job execution.
Priority
Priority configured during job creation is automatically matched. This parameter value can be modified.
Execution Timeout
Timeout of the job instance. If this parameter is set to 0 or is not set, this parameter does not take effect. If the notification function is enabled for the job and the execution time of the job instance exceeds the preset value, the system sends a specified notification, and the job keeps running.
Exclude Waiting Time from Instance Timeout Duration
Whether to exclude the wait time from the instance execution timeout duration
If you select this option, the time to wait before an instance starts running is excluded from the timeout duration. You can modify this setting in Default Configuration > Exclude Waiting Time from Instance Timeout Duration.
If you do not select this option, the time to wait before an instance starts running is included in the timeout duration.
Custom Parameter
Set the name and value of the parameter.
Job Tag
Configure job tags to manage jobs by category.
Click Add to add a tag to the job. You can also select a tag configured in Managing Job Tags.
Table 2 Attributes of the real-time processing single-task MRS Flink SQL job Property
Flink SQL properties
Flink Job Name
Enter the Flink job name.
The name is automatically generated in Workspace-Job name format.
NOTE:It can contain only letters, digits, hyphens (-), and underscores. A maximum of 64 characters are allowed, and Chinese characters are not allowed.
MRS Cluster
Select an MRS cluster.
NOTE:Currently, jobs with a single Flink SQL node support MRS 3.2.0-LTS.1 and later versions.
Program Parameter
Set the job running parameters. This parameter is displayed only after an MRS cluster is selected.
(Optional) Configure optimization parameters such as threads, memory, and vCPUs for the job to optimize resource usage and improve job execution performance.
CAUTION:You can query historical checkpoints and select a specified checkpoint to start a real-time Flink SQL job. To make a Flink checkpoint take effect, configure the following two parameters:Figure 1 Configuring program parameters
NOTE:This parameter is mandatory if the cluster version is MRS 1.8.7 or later than MRS 2.0.1.
Click Select Template and select a parameter template. You can also select multiple templates. For details about how to create templates, see Configuring a Template.
For details about the program parameters of MRS Spark jobs, see Running a Flink Job in the MapReduce Service User Guide.
Flink Job Parameter
Set the parameters for the Flink job.
Variables required for executing the Flink job. These variables are specified by the functions in the Hive script. Multiple parameters are separated by spaces.
NOTE:Do not enter sensitive information, such as the AK, SK, password, and authorization information.
MRS Resource Queue
Select a created MRS resource queue.
Select a queue you configured in the queue permissions of DataArts Security. If you set multiple resource queues for this node, the resource queue you select here has the highest priority.
Rerun Policy
- Rerun from the previous checkpoint
If a Flink real-time jobs fails, the system automatically obtains the latest checkpoint and continues running the job from the checkpoint. If there is no latest checkpoint, the job cannot start.
- Rerun the job
The job is restarted based on the current configuration. No position or checkpoint is required.
Input Data Path
Set the input data path. You can select an HDFS or OBS path.
Output Data Path
Set the output data path. You can select an HDFS or OBS path.
Table 3 Advanced Settings Parameter
Mandatory
Job Status Polling Interval (s)
Yes
Set the interval at which the system checks whether the job is complete. The interval can range from 30s to 60s, or 120s, 180s, 240s, or 300s.
During job execution, the system checks the job status at the configured interval.
Maximum Wait Time
Yes
Set the timeout interval for the job. If the job is not complete within the timeout interval and retry is enabled, the job will be executed again.
NOTE:If the job is in starting state and fails to start, it will fail upon timeout.
Retry upon Failure
Yes
Whether to re-execute the job if it fails
- Yes: The job will be re-executed if it fails. Configure the following parameters:
- Retry upon Timeout
- Maximum Retries
- Retry Interval (seconds)
- No: The job will not be re-executed if it fails. This is the default setting. NOTE:
If retry is configured for a job node and the timeout duration is configured, the system allows you to retry a node when the node execution times out.
If a node is not re-executed when it fails upon timeout, you can go to the Default Configuration page to modify this policy.
Retry upon Timeout is displayed only when Retry upon Failure is set to Yes.
- Enter one or more SQL statements in the SQL editor.
- SQL statements are separated by semicolons (;). If semicolons are used in other places but not used to separate SQL statements, escape them with backslashes (\). The following is an example:
select 1; select * from a where b="dsfa\;"; --example 1\;example 2.
- The script cannot be larger than 1 MB.
- The system date obtained by using an SQL statement is different from that obtained by using the database tool. The query result is stored in the database in the YYYY-MM-DD format, but the query result displayed on the page is in the converted format.
- You can click Check Syntax to check the syntax of Flink SQL jobs. Above the editor, click Check Syntax to check the syntax of SQL statements. After the SQL statement is checked, you can view the syntax check details.
- You can control display of the script execution history by setting Script Execution History in Default Configuration to Myself or All users.
- Do not enter sensitive information, such as the AK, SK, password, and authorization information.
To facilitate script development, DataArts Factory provides the following capabilities:- The script editor supports the following shortcut keys, which improve the script development efficiency:
- F8: Run a script.
- F9: Stop running a script.
- Ctrl + /: Comment out or uncomment the line or code block where the cursor resides.
- Ctrl + Z: Undo an action.
- Ctrl + F: Search for information.
- Ctrl + Shift + R: Replace
- Ctrl + X: Cut
- Ctrl + S: Save a script.
- Alt + mouse dragging: Select columns to edit a block.
- Ctrl + mouse click: Select multiple lines to edit or indent them together.
- Ctrl + → (or ←): Move the cursor rightwards (or leftwards) by word.
- Ctrl + Home or Ctrl + End: Navigate to the beginning or end of the current file.
- Home or End: Navigate to the beginning or end of the current line.
- Ctrl + Shift + L: Double-click all the same character strings and add cursors to them to implement batch modification.
- Ctrl + D: Delete a line.
- Shift + Ctrl + U: Unlock a script.
- Ctrl + Alt + K: Select the word where the cursor resides.
- Ctrl + B: Format
- Ctrl + Shift + Z: Redo
- Ctrl + Enter: Execute the selected line or content.
- Ctrl + Alt + F: Flag
- Ctrl + Shift + K: Search for the previous one.
- Ctrl + K: Search for the next one.
- Ctrl + Backspace: Delete the word to the left of the cursor.
- Ctrl + Delete: Delete the word to the right of the cursor.
- Alt + Backspace: Delete all content from the beginning of the line to the cursor.
- Alt + Delete: Delete all content from the cursor to the end of the line.
- Alt + Shift-Left: Select all content from the beginning of the line to the cursor.
- Alt + Shift-Right: Select all content from the cursor to the end of the line.
- Script parameters
Enter script parameters in the SQL statement and click Parameter Setup in the right pane of the editor and then click Update from Script. You can also directly configure parameters and constants for the job script.
In the following script example, str1 indicates the parameter name. It can contain only letters, digits, hyphens (-), underscores (_), greater-than signs (>), and less-than signs (<), and can contain a maximum of 16 characters. The parameter name must be unique.
select ${str1} from data;
- (Optional) In the upper part of the editor, click Format to format SQL statements.
- Above the editor, click Save to save the job and submit it.
Click Parameters on the right of the editor and set the parameters described in Table 4.
| Function | Description |
| Variables | |
| Add | Click Add and enter the variable parameter name and parameter value in the text boxes.
After the parameter is configured, it is referenced in the format of ${parameter name} in the job. |
| Edit Parameter Expression | Click |
| Modify | Change the parameter name or value in the corresponding text boxes. |
| Mask | If the parameter value is a key, click |
| Delete | Click |
| Constant Parameter | |
| Add | Click Add and enter the constant parameter name and parameter value in the text boxes.
| Modify | Modify the parameter name and parameter value in text boxes and save the modifications. |
| Delete | Click |
| Workspace Environment Variables | |
| View the variables and constants that have been configured in the workspace. | |
Click the Parameter Preview tab and configure the parameters listed in Table 5.
| Current Time | This parameter is displayed only when Scheduling Type is set to Run once. The default value is the current time. |
| Event Triggering Time | This parameter is displayed only when Scheduling Type is set to Event-based. The default value is the time when an event is triggered. |
| Scheduling Period | This parameter is displayed only when Scheduling Type is set to Run periodically. The default value is the scheduling period. |
| Start Time | This parameter is displayed only when Scheduling Type is set to Run periodically. The value is the configured job execution time. |
| Start Time | This parameter is displayed only when Scheduling Type is set to Run periodically. The value is the time when the periodic job scheduling starts. |
| Subsequent Instances | Number of job instances scheduled.
In Parameter Preview, if a job parameter has a syntax error, the system displays a message.
If a parameter depends on the data generated during job execution, such data cannot be simulated and displayed in Parameter Preview.
After configuring the job, click Save to save the job configuration and submit the job.
After the job is saved, a version is automatically generated and displayed in Versions. The version can be rolled back. If you save a job multiple times within a minute, only one version is recorded. If the intermediate data is important, you can click Save new version to save and add a version.
After saving and submitting the job, perform the following operations:
- Click Start above the canvas, select a startup mode, and run the job. When viewing the script execution result, you can double-click a field in any row to view the result details. You can copy the field name.
A maximum of 1,000 records can be displayed in the execution result. The size of the execution result cannot exceed 3 MB. If the size exceeds 3 MB, the result will be truncated.
You can clear the filter criteria for the MRS Flink SQL script execution results displayed in a list with one click.
MRS Flink allows you to trigger savepoints through tenant-plane connections in jobGateway mode. After triggering a savepoint for an MRS Flink job and modifying the job, you can start the job from the savepoint to prevent data loss. (A savepoint is a snapshot of a real-time job at a certain time point. When a Flink real-time job is stopped, the system automatically saves a savepoint. After the job is modified, the job runs from time when the job is stopped.)
Jobs can be started in stateless or stateful mode. In stateless mode, jobs are started without any initial state. In stateful mode, jobs are started with the latest or a specified state. Stateful startup includes the following modes:
- Latest state
- A specified state: Select a checkpoint or savepoint to start the job.
- State set: Select a checkpoint or savepoint from the state set.
- OBS: Select a checkpoint or savepoint from OBS or enter one.
- HDFS: Select a checkpoint or savepoint from HDFS or enter one.
- After the job is executed, choose Job Monitoring and click the Real-Time Jobs tab to view the job execution details.
Templates
When developing a real-time processing, single-task Flink SQL job, you can use a public script template. For details about how to create a template, see Configuring a Template. For details about how to use a script template, see Using Script Templates and Parameter Templates.
