Updated on 2026-11-12 GMT+08:00
IBM Db2 Link Parameters
Table 1 describes the IBM Db2 link parameters.
Do not change the password or user when the job is running. If you do so, the password will not take effect immediately and the job will fail.
Table 1 IBM Db2 link parameters
Example Value
Name
Link name, which should be defined based on the data source type, so it is easier to remember what the link is for
Db2_link
Database Server
Domain name or IP address of the database server. Use semicolons (;) to separate multiple values.
192.168.0.1;192.168.0.2
Port
Port of the database to connect
50,000
Database Name
Name of the database to connect
dbname
Username
Username of the database to connect. The user must have the permission to access the destination database.
cdm
Password
Password of the user
Use Agent
The agent function will be unavailable soon and does not need to be configured.
Agent
Reference Sign
Database enclosure character. This parameter is optional. For some databases, the value is case sensitive. Leave this parameter blank if no enclosure character is required.
Driver Version
Different types of relational databases adapt to different drivers. For details, see How Do I Obtain a Driver?
Fetch Size
(Optional) Displayed when you click Show Advanced Attributes.
Number of rows obtained by each request. Set this parameter based on the data source and the job's data size. If the value is too large or too small, the job execution time may be affected.
1,000
Link Attributes
(Optional) Click Add to add the JDBC connector attributes of multiple specified data sources. For details, see the JDBC connector document of the corresponding database.
The following is an example:
connectTimeout: connection timeout interval, in seconds. The default value is 60.
Link Secret Attributes
It dicaites the custom secret attributes of the link.
sk=xxx
