On this page
Show all
YASHAN Link Parameters
Updated on 2024-10-23 GMT+08:00
Table 1 describes the YASHAN link parameters.
Do not change the password or user when the job is running. If you do so, the password will not take effect immediately and the job will fail.
Table 1 YASHAN link parameters
Example Value
Name
Link name, which should be defined based on the data source type, so it is easier to remember what the link is for
yashan_link
Database Server
IP address or domain name of the database to connect
Click Select next to the text box to obtain the list of instances.
192.168.0.1
Port
Port of the database to connect
1688
Database Name
Name of the database to connect
dbname
Username
Username used for accessing the database This account must have the permissions required to read and write data tables and metadata.
cdm
Password
Password of the user
Use Agent
The agent function will be unavailable soon and does not need to be configured.
Agent
Reference Sign
(Optional) Delimiter between the names of the referenced tables or columns. For details, see the product documentation of the corresponding database.
Driver Version
Different types of relational databases adapt to different drivers. For details, see How Do I Obtain a Driver?
Fetch Size
(Optional) Displayed when you click Show Advanced Attributes.
Number of rows obtained by each request. Set this parameter based on the data source and the job's data size. If the value is too large or too small, the job execution time may be affected.
1000
SSL Encryption
Select Yes if you want to enable SSL encrypted transmission.
Yes
Link Attributes
(Optional) Click Add to add the JDBC connector attributes of multiple specified data sources. For details, see the JDBC connector document of the corresponding database.
The following are some examples:
  • socketTimeout: JDBC connection timeout duration, in milliseconds
  • mysql.bool.type.transform: whether to parse tinyint(1) to a Boolean value during data reading from a MySQL database. The default value is true.
socketTimeout=300
Link Secret Attributes
Custom secret attributes of the link
xxx=xxx
