LTS Connection Parameters (Internal Test)
Parameter |
Mandatory |
Description |
Data Connection Type |
Yes |
LTS is selected by default and cannot be changed. |
Name |
Yes |
Name of the data connection to create. Data connection names can contain a maximum of 100 characters. They can contain only letters, digits, underscores (_), and hyphens (-). |
Description |
No |
A description which can help identify the data connection more easily. It can contain a maximum of 100 characters. |
Tag |
No |
Attribute of the data connection to create. Tags make management easier.
The tag name can contain only letters, digits, and underscores (_) and cannot start with an underscore (_) or contain more than 100 characters. |
Applicable Modules |
Yes |
Select the modules for which this connection is available.
Basic and Network Connectivity Configuration |
Project ID |
Yes |
This parameter is displayed when DataArts Migration is selected for Applicable Modules. Project ID in the region where DLI resides
A project is a group of tenant resources, and an account ID corresponds to the current account. The IAM ID corresponds to the current user. You can view the project IDs, account IDs, and user IDs in different regions on the corresponding pages.
KMS Key |
Yes |
KMS key used to encrypt and decrypt data source authentication information. Select a default or custom key.
Agent |
Yes |
DataArts Studio cannot be directly connected to non-fully managed services. A CDM cluster can provide an agent for DataArts Studio to communicate with non-fully-managed services. Therefore, you need to select a CDM cluster when creating an LTS data connection. If no CDM cluster is available, create one first by referring to Creating a CDM Cluster. |
Data Migration Configuration |
Domain Name |
Yes |
Address for accessing the cluster database through an internal network. Enter a domain name. The domain name is automatically generated during cluster creation. You can obtain them on the management console by performing the following operations:
Data Source Authentication and Other Function Configuration |
AK |
Yes |
OBS AK Example: HCXUET8G37MWF |
SK |
No |
SK corresponding to the OBS AK |
