Updated on 2026-05-20 GMT+08:00
Viewing Monitoring Metrics
After you start a real-time migration job, Cloud Eye automatically associates monitoring metrics of the job. This helps you learn the status of the job.
It takes some time for the system to obtain and transmit monitoring data, so the job status displayed on the Job Monitoring page is not up-to-date. If you just started a real-time migration job, wait for 5 to 10 minutes and then view the monitoring data.
  • You have obtained required Cloud Eye permissions.
  • The real-time migration job is running properly. If it has been stopped or is abnormal, you can only view its monitoring metrics in the last seven days.
  • The real-time migration job has been running properly for about 10 minutes.
Supported Monitoring Metrics
Table 1 lists the monitoring metrics supported for real-time processing migration jobs.
Table 1 Monitoring metrics supported for real-time processing migration jobs
Metric ID
Metric Name
Value Range
Unit
Conversion Rule
Dimension
Monitoring Period (Raw Data)
extract_latency
Source Database WAL Extract Lag
Latency of extracting WALs from the source database
≥ 0 ms
ms
N/A
dm_di_job_id
1 minute
flink_read_records_per_second
Flink job data read rate
Data input rate of a Flink job for monitoring and debugging
≥ 0 record/s
record/s
N/A
dm_di_job_id
1 minute
flink_write_records_per_second
Flink job data write rate
Data output rate of a Flink job for monitoring and debugging
≥ 0 record/s
record/s
N/A
dm_di_job_id
1 minute
flink_read_records_total
Flink job total data read
Total number of data inputs of a Flink job for monitoring and debugging
≥ 0 record/s
record/s
N/A
dm_di_job_id
1 minute
flink_write_records_total
Flink job total data write
Total number of output data records of Flink jobs for monitoring and debugging.
≥ 0 record/s
record/s
N/A
dm_di_job_id
1 minute
flink_read_bytes_per_second
Flink job byte read rate
Input bytes of a Flink job per second
≥ 0 Byte/s
Byte/s
1024(IEC)
dm_di_job_id
1 minute
flink_write_bytes_per_second
Flink job byte write rate
Output bytes of a Flink job per second
≥ 0 Byte/s
Byte/s
1024(IEC)
dm_di_job_id
1 minute
flink_read_bytes_total
Flink job total read byte
Total number of input bytes of a Flink job
≥ 0 Byte
Byte
1024(IEC)
dm_di_job_id
1 minute
flink_write_bytes_total
Flink job total write byte
Total number of output bytes of a Flink job
≥ 0 Byte
Byte
1024(IEC)
dm_di_job_id
1 minute
flink_cpu_usage
Flink job CPU usage
CPU usage of a Flink job
0% to 100%
N/A
dm_di_job_id
1 minute
flink_mem_usage
Flink job memory usage
Memory usage of a Flink job
0% to 100%
N/A
dm_di_job_id
1 minute
flink_max_op_latency
Flink job max operator latency
Maximum operator latency of a Flink job
≥ 0 ms
ms
N/A
dm_di_job_id
1 minute
flink_max_op_backpressure_level
Flink job max operator back pressure
Maximum operator back pressure value of a Flink job. The value ranges from 0 to 1. A larger value indicates severer back pressure.
0 to 1
N/A
dm_di_job_id
1 minute
binlog_file_read_per_second
Binlog Files Read per Second
Number of binlog files read per second
≥ 0 count/s
count/s
N/A
dm_di_job_id
1 minute
binlog_file_read_total
Total Binlog Files Read
Total number of binlog files read
≥ 0 count
count
N/A
dm_di_job_id
1 minute
binlog_bytes_per_second
Binlog Bytes Read per Second
Number of binlog bytes read per second
≥ 0 byte/s
bytes/s
1024(IEC)
dm_di_job_id
1 minute
binlog_bytes_total
Total Binlog Bytes Read
Total number of binlog bytes read
≥ 0 bytes
bytes
1024(IEC)
dm_di_job_id
1 minute
insert_sink_num
Data Records Inserted at the Destination
Number of data records inserted at the destination
≥ 0 count
count
N/A
dm_di_job_id
1 minute
update_sink_num
Data Records Updated at the Destination
Number of data records updated at the destination
≥ 0 count
count
N/A
dm_di_job_id
1 minute
delete_sink_num
Data Records Deleted at the Destination
Number of data records deleted at the destination
≥ 0 count
count
N/A
dm_di_job_id
1 minute
dirty_records_out
Dirty data records total
Number of dirty data records
≥ 0 count
records
N/A
dm_di_job_id
1 minute
dirty_bytes_out
Dirty data bytes total
Number of dirty data bytes
≥ 0 bytes
bytes
1024(IEC)
dm_di_job_id
1 minute
unsupport_ddls_num
Unsupported ddl statement count
Total number of unsupported DDL statements
≥ 0 count
count
N/A
dm_di_job_id
1 minute
ignored_ddls_num
Ignored ddl statement count
Total number of ignored DDL statements
≥ 0 count
count
N/A
dm_di_job_id
1 minute
job_retry_times
Job retry times
Number of job retries
≥ 0 count
count
N/A
dm_di_job_id
1 minute
queue_job_launching_num
Jobs being submitted
Number of jobs being submitted in a queue
≥ 0 count
Count
N/A
dm_di_job_id
6 minutes
queue_job_running_num
Running jobs
Number of running jobs in a queue
≥ 0 count
Count
N/A
dm_di_job_id
6 minutes
queue_job_succeed_num
Finished jobs
Number of finished jobs in a queue
≥ 0 count
Count
N/A
dm_di_job_id
6 minutes
queue_job_failed_num
Failed jobs
Number of failed jobs in a queue
≥ 0 count
Count
N/A
dm_di_job_id
6 minutes
queue_job_cancelled_num
Canceled jobs
Number of canceled jobs in a queue
≥ 0 count
Count
N/A
dm_di_job_id
6 minutes
elastic_resource_pool_cpu_usage
CPU usage (elastic resource pool)
Percentage of used CPUs to total CPUs of a resource pool
0% ~ 100%
N/A
dm_di_job_id
6 minutes
elastic_resource_pool_mem_usage
Memory usage (elastic resource pool)
Percentage of the used memory to the total memory of a resource group
0% ~ 100%
N/A
dm_di_job_id
6 minutes
elastic_resource_pool_disk_usage
Disk usage (elastic resource pool)
Percentage of the used disks to the total disks of a resource group
0% ~ 100%
N/A
dm_di_job_id
6 minutes
elastic_resource_pool_disk_max_usage
Max disk usage (elastic resource pool)
Maximum disk usage of a resource group
0% ~ 100%
N/A
dm_di_job_id
6 minutes
elastic_resource_pool_cu_num
CU usage (elastic resource pool)
CUs used by an elastic resource pool
≥ 0 count
Count
N/A
dm_di_job_id
6 minutes
elastic_resource_pool_min_cu_num
Mini CUs (elastic resource pool)
Minimum CUs allowed for an elastic resource pool
≥ 0 count
Count
N/A
dm_di_job_id
6 minutes
elastic_resource_pool_max_cu_num
Max CUs (elastic resource pool)
Maximum CUs allowed for an elastic resource pool
≥ 0 count
Count
N/A
dm_di_job_id
6 minutes
elastic_resource_pool_alloc_cu_num
Allocated CUs (elastic resource pool)
Total number of elastic resource pool CUs that are allocated to queues
≥ 0 count
Count
N/A
dm_di_job_id
6 minutes
apply_ddls_number
DDLs
Total number of DDL transactions written into the destination database
≥ 0 count
Count
N/A
dm_di_job_id
1 minute
network_incoming_bytes_rate
Network Input Throughput
Incoming traffic in bytes per second
≥ 0 byte/s
byte/s
1024(IEC)
dm_di_job_id
1 minute
network_outgoing_bytes_rate
Network Output Throughput
Outgoing traffic in bytes per second
≥ 0 byte/s
byte/s
1024(IEC)
dm_di_job_id
1 minute
disk_read_bytes_rate
Disk Read Throughput
Number of bytes read from the disk per second
≥ 0 byte/s
byte/s
1024(IEC)
dm_di_job_id
1 minute
disk_write_bytes_rate
Disk Write Throughput
Number of bytes written to the disk per second
≥ 0 byte/s
byte/s
1024(IEC)
dm_di_job_id
1 minute
disk_util
Storage Space Usage
Storage space usage of the monitored object
0% ~ 100%
N/A
dm_di_job_id
1 minute
extract_bytes_rate
Source Database Read Throughput
Table data or WAL bytes read from a source database per second
≥ 0 byte/s
byte/s
1024(IEC)
dm_di_job_id
1 minute
extract_rows_rate
Rows Read from Source Database per Second
Number of table data rows or WAL rows read from a source database per second
≥ 0 row/s
row/s
N/A
dm_di_job_id
1 minute
apply_bytes_rate
Destination Database Write Throughput
Number of bytes written to the destination database per second
≥ 0 byte/s
byte/s
1024(IEC)
dm_di_job_id
1 minute
apply_rows_rate
Rows Written into Destination Database per Second
Number of rows written into the destination database per second
≥ 0 row/s
row/s
N/A
dm_di_job_id
1 minute
lag_records
Unconsumed Data
Number of unconsumed data records
≥ 0 records
records
N/A
dm_di_job_id
1 minute
insert_num
Insert count
Number of data insertions
≥ 0 count
Count
N/A
dm_di_job_id
1 minute
update_num
Update count
Number of data updates
≥ 0 count
Count
N/A
dm_di_job_id
1 minute
delete_num
Delete count
Number of data deletion times
≥ 0 count
Count
N/A
dm_di_job_id
1 minute
apply_transactions_rate
DML TPS
Number of DML transactions written into the destination database per second
≥ 0 transaction/s
transaction/s
N/A
dm_di_job_id
1 minute
apply_ddls_rate
DDL TPS
Number of DDL transactions written into the destination database per second
≥ 0 record/s
record/s
N/A
dm_di_job_id
1 minute
apply_latency
Data Synchronization Latency
Data synchronization latency
≥ 0 ms
ms
N/A
dm_di_job_id
1 minute
Dimension
Key
Value
dm_di_job_id
ID of a real-time processing integration job.
You can obtain the value from customer service or technical support.
  1. Log in to the DataArts Studio console by following the instructions in Accessing the DataArts Studio Instance Console.
  2. On the DataArts Studio console, locate a workspace and click DataArts Factory.
  3. In the left navigation pane of DataArts Factory, choose Monitoring > Job Monitoring.
  4. On the Real-Time Migration Jobs page, click a job name.
    Figure 1 Monitoring a real-time migration job
  5. On the details page, click the Monitoring Information tab. You can view some key metrics of the job at the bottom of the page.
    Figure 2 Key metrics
  6. Click View Monitoring Metrics to go to the Cloud Eye console and view monitoring metrics.
    Figure 3 Viewing monitoring metrics
    For more information about monitoring metrics, see the Cloud Eye User Guide.
