Updated on 2026-09-14 GMT+08:00
Supported Data Sources
The following table lists the data sources supported by real-time migration jobs.
Table 1 Data sources supported by real-time migration jobs
Source
Destination
Synchronization Scenario
Reference
MySQL and TaurusDB
Deployment mode: standalone, primary/standby (connected to the primary database), or PXC
Deployment method: on-premises, other clouds, or RDS
MRS Hudi
Entire DB
Database/Table shard
  • Supported MySQL database versions: 5.6, 5.7, and 8.x
  • Supported Hudi version: 0.11.0
StarRocks (internal test)
Entire DB
Configuring a Job for Synchronizing Data from MySQL to StarRocks (Internal Beta)
  • Supported StarRocks versions: 3.x
    This connection is available only after you apply for the whitelist membership. To use it, contact customer service or technical support.
Doris (in OBT)
Entire DB
  • Supported Doris versions: Doris 1.2 and Doris 2.0
Kafka
Entire DB
  • Supported Kafka cluster versions: 2.7 and 3.x
DWS
Entire DB
  • Supported DWS cluster versions: 8.1.3, 8.2.0, and later, except DWS 3.0
Elasticsearch (internal test)
Entire DB
Configuring a Job for Synchronizing Data from MySQL to Elasticsearch (Internal Test)
  • Supported Elasticsearch database versions: 7.x, 5.x, and 6.x
SQL Server
Deployment mode: standalone or primary/standby (connected to the primary database)
DWS (in OBT)
Entire DB
  • Supported SQL Server versions: Enterprise Edition 2016, 2017, 2019, and 2022; Standard Edition 2016 SP2 and later, 2017, 2019, and 2022
  • Supported DWS versions: 8.1.3, 8.2.0, and later, except DWS 3.0
MRS Hudi (in OBT)
Entire DB
PostgreSQL
DWS
Entire DB
  • Supported PostgreSQL database versions: PostgreSQL 9.4, 9.5, 9.6, 10, 11, 12, 13, 14, 15, and 16
MRS Hudi (internal test)
Entire DB
Doris (in OBT)
Entire DB
Open Gauss (GaussDB)
Deployment mode: centralized standalone, centralized primary/standby (connected to the primary database), and distributed primary/standby (connected to the primary database)
Deployment mode: Huawei Cloud GaussDB
DWS
Entire DB
  • Supported centralized/distributed GaussDB versions: kernel engine versions 505.1.0, 505.1.0.SPC0100, and 505.2.0
Entire DB
Doris (in OBT)
Entire DB
Kafka
Entire DB
Configuring a Job for Synchronizing Data from a Centralized/Distributed GaussDB to DMS for Kafka
  • Supported Kafka versions: 2.7 and 3.x
Oracle
Deployment mode: standalone or primary/standby (non-RAC architecture)
DWS
Entire DB
  • Supported Oracle database versions: 10g, 11g, 12c, and 19c
Kafka
Entire DB
Configuring a Job for Synchronizing Data from Oracle to DMS for Kafka
  • Supported Oracle database versions: 10, 11, 12, and 19
MRS Hudi
Entire DB
Entire DB
Doris (internal test)
Entire DB
Kafka
Deployment method: on-premises or other clouds
Single table
Configuring a Job for Synchronizing Data from DMS for Kafka to Doris (Internal Test)
OBS
Single table
Entire DB
Kafka
Entire DB
Hudi (in OBT)
Single table
MongoDB
DWS (internal test)
Single table
Configuring a Job for Synchronizing Data from MongoDB to DWS (Internal Test)
  • Supported MongoDB versions: 4.0.0 and later
