MRS Iceberg
DataArts Migration supports the main versions of MRS Iceberg, meeting your data synchronization requirements in various deployment environments.
Preparation and Constraints
- Network requirements
The MRS Iceberg data source can communicate with CDM. This ensures smooth data transmission. For details, see Enabling Network Connectivity.
- Required permissions
- Iceberg read and write permissions
- Read permission: Grant the read-only permission of Iceberg to the IAM user or user group of DataArts Migration through a system policy such as MRS ReadOnlyAccess. You can also create a custom policy to grant read permissions such as SELECT.
- Write permission: In addition to the preceding OBS permissions, you need to grant the write permission of Iceberg to the IAM user or user group of DataArts Migration through a system policy such as MRS CommonOperations and MRS FullAccess. You can also create a custom policy to grant write permissions such as INSERT INTO TABLE and CREATE TABLE.
- OBS permissions (storage and compute analysis): When storage and compute analysis is enabled for MRS Iceberg, DataArts Migration reads files from and writes files to OBS. In this case, you must have the read and write permissions on OBS files.
- Enabling access ports: When configuring the MRS Iceberg data source, ensure that the following ports have been enabled in the security group or network so that DataArts Migration can access MRS.
Table 1 Service ports Service
Port Type
Port Number
Spark
TCP
22550
Spark JDBC Thrift port, which is used for the communications between the Spark client and Spark server
MRS
Manager
TCP
28443
Used to download the MRS cluster configuration
20009
Used for CAS authentication
20029
Used by Manager to communicate with and manage other components
KDC
TCP&&UDP
21730
Used for Kerberos authentication
21731
HDFS
TCP
8020
HDFS NameNode service port
Hive
TCP
10000
HiveServer port used for communication between the client and HiveServer
9083
Hive Metastore service port used to store and manage Hive metadata
Zookeeper
TCP
2181
ZooKeeper service port used for communication between the client and ZooKeeper cluster
JobGateway
TCP
29974
JobBalancer port used for communication between the client and JobBalancer
Supported Data Types
DataArts Migration can read the following types of fields from MRS Iceberg based on the Spark read capability.
| Type | Field Type | MRS Iceberg Read | MRS Iceberg Write |
| String | STRING | √ | √ |
| Integer | INTEGER | √ | √ |
| LONG | √ | √ | |
| Floating point | FLOAT | √ | √ |
| DOUBLE | √ | √ | |
| DECIMAL | √ | √ | |
| Date/Time | DATE | √ | √ |
| TIMESTAMP | √ | √ | |
| TIMESTAMP_NTZ | √ | √ | |
| Boolean | BOOLEAN | √ | √ |
| Binary | BINARY | √ | √ |
| Complex type | ARRAY | √ | x |
| MAP | √ | x | |
| STRUCT | x | x |
Supported Migration Scenarios
DataArts Migration supports the following modes for synchronizing on-premises data:
Database and table shard synchronization and entire DB migration are not supported in all regions. The following table lists the migration scenarios supported by MRS Iceberg.
| Supported Migration Scenario | Single Table Read | Single Table Write | Database/Table Shard Read | Database/Table Shard Write | Entire DB Read | Entire DB Write |
| Supported | √ | √ | x | √ | x | x |
Creating an Offline Data Migration Job
Create an MRS Iceberg migration job in DataArts Factory. For details, see Creating an Offline Processing Migration Job.
