RestApi
RestApi is a tool used to construct and send HTTP requests to interact with RESTful web services. It features high usability, flexibility, and scalability, and is widely used in data exchange and integration between different systems. DataArts Migration supports RestApi and can access and read data from structured and semi-structured data sources, and efficiently migrate and write data to meet complex data integration requirements.
Preparation and Constraints
Network requirements
The RestApi data source can communicate with CDM. This ensures smooth data transmission. For details, see Enabling Network Connectivity.
Supported Migration Scenarios
DataArts Migration supports the following modes for synchronizing on-premises data:
- Single table synchronization
DataArts Migration supports table/file synchronization in data ingestion into a data lake or data migration to the cloud.
- Database and table shard synchronization
DataArts Migration supports synchronization of data from multiple databases and tables in data ingestion into a data lake or data migration to the cloud.
- Entire DB migration
DataArts Migrations supports synchronization of data from an on-premises database in data ingestion into a data lake or data migration to the cloud.
Database and table shard synchronization and entire DB migration are not supported in all regions. The following table lists the supported RestApi data migration scenarios.
| Supported Migration Scenario | Single Table Read | Single Table Write | Database/Table Shard Read | Database/Table Shard Write | Entire DB Read | Entire DB Write |
| Supported | √ | x | x | x | x | x |
Core Capabilities
- Connection configuration
Configuration Item
Supported
Supported request types
GET
POST
Two most common HTTP request types are supported.
Authentication types
NONE
BASIC_AUTH
TOKEN_AUTH
OAUTH_CODE_GRANT
- NONE: no authentication
- BASIC_AUTH: basic authentication
If the data source API supports username and password authentication, you can select this authentication type and configure the username and password used for authentication. When the data source is connected, the username and password are transferred to the RESTful address through the Basic Auth protocol for authentication. The format is {"Authorization":"Basic base64(username:password)"}.
- TOKEN_AUTH: token authentication (The token is static and never expires. Otherwise, jobs will fail if the token expires.)
If the data source API supports token-based authentication., you can select this authentication type and set a fixed token for authentication. When the data source is connected, the token is transferred to the header for authentication. The format is {"Authorization":"Bearer <token>"}.
- OAUTH_CODE_GRANT Oauth 2.0 (Authorization Code): Oauth2.0 authentication
In this mode, a username and a password are used to obtain an access token, which is used to access APIs.
- Read capabilities
Configuration Item
Supported
Incremental read
The URL or body can be modified to enable incremental read.
Concurrent read
Horizontal sharding based on pages and multi-thread concurrent extraction significantly improve the throughput and efficiency.
Nested JSON parsing
The JSON data structure in the response body can be parsed. JSON data with multiple layers of nested fields can be correctly processed, ensuring data integrity and accuracy.
Creating a Data Source
Create a data source in Management Center. For details, see Configuring Data Connection Parameters.
Creating an Offline Data Migration Job
Create a ResApi migration job in DataArts Factory. For details, see Creating an Offline Processing Migration Job.
