Updated on 2026-05-20 GMT+08:00
MRS HBase data source
The data integration service supports MRS HBase 1.x and 2.x, meeting data synchronization requirements of different users in different deployment environments.
Preparation and Constraints
  • Network requirements
    The MRS HBase data source must communicate with the CDM network to ensure smooth data transmission. For details, see Enabling Network Connectivity.
  • Required permissions
    • Read permission: To read data from HBase, you need to assign the read-only permission of HBase to the IAM user or user group of the data integration service, for example, the MRS ReadOnlyAccess system policy. Alternatively, you can create a custom policy as required to assign the read-related permissions such as SELECT to the user or user group.
    • Write permission: To write data to HBase, in addition to the preceding OBS permissions, you need to grant the IAM user or user group of the data integration service the HBase write permission, for example, the MRS CommonOperations or MRS FullAccess system policy. You can also create a custom policy, grants write-related permissions, such as INSERT INTO TABLE and CREATE TABLE.
  • Access port: The bound ports vary depending on the MRS version. For details, see Common Ports for MRS Cluster Services.
    Table 1 Service ports
    Service
    Port
    Port Number
    Usage
    MRS Manager
    TCP
    28443
    Download the cluster configuration.
    TCP
    20009
    CAS authentication.
    TCP
    20029
    Internal communication of Manager.
    KDC
    TCP&UDP
    21730
    21731
    21732
    Kerberos Authentication
    HDFS
    TCP
    8020
    HDFS NameNode service port
    TCP
    9866
    HDFS dataNode service port
    HBase
    TCP
    16000
    HBase Master RPC port.
    TCP
    16020
    HBase RegionServer RPC port.
    ZooKeeper
    TCP
    2181
    ZooKeeper service port used for communications between the client and ZooKeeper cluster
Supported Migration Scenarios
DataArts Migration supports the following offline synchronization modes:
  • Single table synchronization
    DataArts Migration supports table/file synchronization in data ingestion into a data lake or data migration to the cloud.
  • Database and table shard synchronization
    DataArts Migration supports synchronization of data from multiple databases and tables in data ingestion into a data lake or data migration to the cloud.
  • Entire DB migration
    DataArts Migrations supports synchronization of data from an on-premises database in data ingestion into a data lake or data migration to the cloud.
Database and table shard synchronization and entire DB migration are not supported in all regions. The following table lists the migration scenarios supported by MRS HBase.
Single Table Read
Single Table Write
Database/Table Shard Read
Database/Table Shard Write
Entire DB Read
Entire DB Write
Supported
x
x
x
Core Capabilities
  • Connection configuration
    Configuration Item
    Supported
    Authentication Mode
    SIMPLE
    KERBEROS
    The MRS cluster can be accessed in SIMPLE/KERBEROS authentication mode.
    Supported Versions
    1.x
    2.x
    Supports the read and write capabilities of HBase 1.x/2.x.
    SSL Authentication
    x
    HBase SSL authentication access, which ensures data transmission security. Currently, this capability is not supported.
  • Read capabilities
    Configuration Item
    Supported
    Incremental read
    The [RowKey condition] or [Start/End time] mode is supported to implement incremental read.
    Shard concurrency
    Supports horizontal sharding based on regions and multi-thread parallel extraction, significantly improving throughput efficiency.
    Custom fields
    You can add computed columns, constant columns, or masking functions for tasks to meet personalized service requirements.
    Dirty data processing
    Abnormal data can be written to the dirty data bucket to prevent job failures caused by a small amount of abnormal data.
  • Write capabilities
    Configuration Item
    Supported
    Clear Data Before Import
    Data can be cleared before being imported.
    Concurrent write
    Concurrent write improves efficiency.
Creating a Data Source
Create a data source in Management Center. For details, see Configuring Data Connection Parameters.
Creating an Offline Data Migration Job
Create a DataArts Fabric SQL integration job in DataArts Studio data development. For details, see Creating an Offline Processing Migration Job.
