GBase
GBase is a distributed analytics database with high performance, reliability, and security. It is widely used in big data analytics and real-time decision-making support.
DataArts Migration can migrate GBase data.
Preparation and Constraints
- Network requirements
The GBase data source can communicate with CDM. This ensures smooth data transmission. For details, see Enabling Network Connectivity.
- Required permissions
- Reading data from GBase: The account must have the read-only permission (SELECT) on the table to be synchronized so that data can be read securely and accurately.
- Writing data to GBase: The account must have the write permission (INSERT, DELETE, UPDATE, and CREATE) on the table to be synchronized so that data can be correctly written to the destination table.
Driver Selection
| Driver Name | How to Obtain | Recommended Version |
| com.gbase.jdbc.Driver | 8.3.81.53 |
Supported Data Types
| Category | Field Type | GBase Read | GBase Write |
| Integer | TINYINT | √ | √ |
| SMALLINT | √ | √ | |
| MEDIUMINT | √ | √ | |
| INT | √ | √ | |
| BIGINT | √ | √ | |
| Floating point number | FLOAT | √ | √ |
| DOUBLE | √ | √ | |
| DECIMAL | √ | √ | |
| Character | CHAR | √ | √ |
| VARCHAR | √ | √ | |
| TINYTEXT | √ | √ | |
| TEXT | √ | √ | |
| MEDIUMTEXT | √ | √ | |
| LONGTEXT | √ | √ | |
| Boolean | BOOLEAN | √ | √ |
| Time | DATE | √ | √ |
| DATETIME | √ | √ | |
| TIMESTAMP | √ | √ | |
| TIME | √ | √ |
Supported Migration Scenarios
DataArts Migration supports the following modes for synchronizing on-premises data:
- Single table synchronization
DataArts Migration supports table/file synchronization in data ingestion into a data lake or data migration to the cloud.
- Database and table shard synchronization
DataArts Migration supports synchronization of data from multiple databases and tables in data ingestion into a data lake or data migration to the cloud.
- Entire DB migration
DataArts Migrations supports synchronization of data from an on-premises database in data ingestion into a data lake or data migration to the cloud.
Database and table shard synchronization and entire DB migration are not supported in all regions. The following table lists the supported GBase data migration scenarios.
| Supported Migration Scenario | Single Table Read | Single Table Write | Database/Table Shard Read | Database/Table Shard Write | Entire DB Read | Entire DB Write |
| Supported | √ | √ | x | √ | x | x |
Core Capabilities
- Connection configuration
Configuration Item
Supported
User/AK
User authentication ensures connection security.
SSL encryption authentication
x
SSL encryption ensures secure data transmission. Currently, this function is not supported.
Connection configuration optimization
Connection configuration such as connectTimeout can be optimized to improve connection performance.
Custom driver
Custom drivers are supported and provide better flexibility.
- Read capabilities
Configuration Item
Supported
Incremental read
Where conditions and the SQL mode enable incremental data reading.
Shard concurrency
Horizontal sharding based on primary keys or common fields and multi-thread concurrent extraction significantly improve the throughput and efficiency.
Dirty data processing
Abnormal data can be written to the dirty data bucket to prevent job failures caused by a small amount of abnormal data.
Custom fields
You can add computed columns, constant columns, or masking functions for tasks to meet personalized service requirements.
- Write capabilities
Configuration Item
Supported
Pre- and post-import processing
Operations such as preSql and delete can clean and process data before and after data import.
Concurrent write
Concurrent write improves efficiency.
Optimization of the number of written rows
You can improve write performance by adjusting the values of parameters Commit Size and Batch Size in the connection configuration.
Creating a Data Source
Create a data source in Management Center. For details, see Configuring Data Connection Parameters.
Creating an Offline Data Migration Job
Create a GBase migration job in DataArts Factory. For details, see Creating an Offline Processing Migration Job.
