Updated on 2026-08-21 GMT+08:00
SFTP
DataArts Migration allows you to read and write SFTP data.
Preparation and Constraints
  • Network requirements
    The SFTP data source can communicate with CDM. This ensures smooth data transmission. For details, see Enabling Network Connectivity.
  • Enabling ports
    SFTP port (22): TCP 22 must be enabled so that DataArts Migration can access the SFTP data source.
Supported Migration Scenarios
DataArts Migration supports the following modes for synchronizing on-premises data:
  • Single table synchronization
    DataArts Migration supports table/file synchronization in data ingestion into a data lake or data migration to the cloud.
  • Database and table shard synchronization
    DataArts Migration supports synchronization of data from multiple databases and tables in data ingestion into a data lake or data migration to the cloud.
  • Entire DB migration
    DataArts Migrations supports synchronization of data from an on-premises database in data ingestion into a data lake or data migration to the cloud.
Database and table shard synchronization and entire DB migration are not supported in all regions. The following table lists the supported SFTP data migration scenarios.
Single Table Read
Single Table Write
Database/Table Shard Read
Database/Table Shard Write
Entire DB Read
Entire DB Write
Supported
Supported in some regions
x
x
x
Core Capabilities
  • Connection configuration
    Configuration Item
    Supported
    Authentication mode
    Username and password
    Only SFTP usernames and passwords can be used for authentication.
    Keys cannot be used for authentication.
  • Read capabilities
    Configuration Item
    Supported
    Incremental read
    You can configure the variable path and scheduling to trigger incremental synchronization based on time or file changes.
    Supported file formats
    Binary
    CSV
    JSON
    Raw binary files can be read. This is applicable to migration between file systems.
    The standard CSV format is supported. Delimiters and encoding modes can be identified.
    JSON structures can be parsed, and multiple JSON fields can be extracted.
    Shard concurrency
    Multiple threads can run concurrently to read data from files, significantly improving the throughput.
    Dirty data processing
    Abnormal data can be written to the dirty data bucket to prevent job failures caused by a small amount of abnormal data.
    Custom fields
    You can add computed columns, constant columns, or masking functions for tasks to meet personalized service requirements.
  • Write capabilities
    Configuration Item
    Supported
    Binary
    CSV
    Raw binary files can be written. This is applicable to migration between file systems.
    x
    Abnormal data cannot be written to the dirty data bucket to prevent job failures caused by a small amount of abnormal data.
Creating a Data Source
Create a data source in Management Center. For details, see Configuring Data Connection Parameters.
Creating an Offline Data Migration Job
Create an SFTP migration job in DataArts Factory. For details, see Creating an Offline Processing Migration Job.
