Updated on 2026-05-20 GMT+08:00
MongoDB
MongoDB is a document-oriented NoSQL database that stores data in JSON format. It supports high concurrency and scale-out.
DataArts Migration supports the main versions of open-source and cloud MongoDB, meeting your data synchronization requirements in various deployment environments.
Preparation and Constraints
  • Network requirements
    The MongoDB data source can communicate with CDM. This ensures smooth data transmission. For details, see Enabling Network Connectivity.
  • Required permissions
    • Read permission: Assign the read built-in role so that DataArts Migration can read data from a destination MongoDB. This role allows users to perform read operations, such as find, aggregate, listCollections, and listIndexes.
    • Write permission: Assign the readWrite built-in role so that DataArts Migration can write data to a destination MongoDB. This role has all the permissions of the read role as well as the permissions to perform write and structure change operations, such as insert, update, remove, createCollection, and createIndex.
  • Enabling ports
    MongoDB port (27017): TCP 27017 and the listening ports of the replica set or sharded cluster must be enabled so that DataArts Migration can access MongoDB.
Supported Data Types
The following table lists the MongoDB data types supported by DataArts Migration.
Category
Field Type
Read
Write
Numeric
Integer
Long
Double
Decimal
ObjectId
ObjectId
Time
Date
Timestamp
Document
Document
Character
String
Array
Array
Boolean
Boolean
Binary
Binary
Null
Null
Supported Migration Scenarios
DataArts Migration supports the following modes for synchronizing on-premises data:
  • Single table synchronization
    DataArts Migration supports table/file synchronization in data ingestion into a data lake or data migration to the cloud.
  • Database and table shard synchronization
    DataArts Migration supports synchronization of data from multiple databases and tables in data ingestion into a data lake or data migration to the cloud.
  • Entire DB migration
    DataArts Migrations supports synchronization of data from an on-premises database in data ingestion into a data lake or data migration to the cloud.
Database and table shard synchronization and entire DB migration are not supported in all regions. The following table lists the supported MongoDB migration scenarios.
Single Table Read
Single Table Write
Database/Table Shard Read
Database/Table Shard Write
Entire DB Read
Entire DB Write
Supported
x
x
x
Core Capabilities
  • Connection configuration
    Configuration Item
    Supported
    Support for Secure Shell (SSL)
    x
    SSL encryption ensures secure data transmission. Currently, this function is not supported.
  • Read capabilities
    Configuration Item
    Supported
    Incremental read
    The find condition can be configured to enable incremental read.
    Shard concurrency
    x
    Concurrent read can fully utilize resources and improve read performance. MongoDB links do not support this function.
    Nested document parsing
    Nested document data structures can be parsed. Document data with multiple layers of nested fields can be correctly processed, ensuring data integrity and accuracy.
    Custom fields
    You can add computed columns, constant columns, or masking functions for tasks to meet personalized service requirements.
    Dirty data processing
    Abnormal data can be written to the dirty data bucket to prevent job failures caused by a small amount of abnormal data.
  • Write capabilities
    Configuration Item
    Supported
    Data clearance before import
    Operations such as preSql can clean and process data before data import.
    Conflict resolution
    Multiple write modes, such as addition and replacement, can flexibly handle data conflicts.
    Concurrent write
    Concurrent write improves efficiency.
Creating a Data Source
Create a data source in Management Center. For details, see Configuring Data Connection Parameters.
Creating an Offline Data Migration Job
Create a MongoDB migration job in DataArts Factory. For details, see Creating an Offline Processing Migration Job.
