Updated on 2026-05-20 GMT+08:00
MRS ClickHouse
Huawei Cloud MRS ClickHouse is a columnar database oriented to online analysis and processing. It is independent of the Hadoop big data system and features compression rate and fast query performance. In addition, ClickHouse supports SQL query and provides good query performance, especially the aggregation analysis and query performance based on large and wide tables. The query speed is one order of magnitude faster than that of other analytical databases.
DataArts Migration supports Huawei Cloud MRS ClickHouse and the stable transmission and processing of MRS ClickHouse data ingested into and exported from data lakes.
Preparation and Constraints
  • Network requirements
    The MRS ClickHouse data source can communicate with CDM. This ensures smooth data transmission. For details, see Enabling Network Connectivity.
  • Required permissions
    • Read permission: Grant the read-only permission of ClickHouse to the IAM user or user group of DataArts Migration through a system policy such as MRS ReadOnlyAccess. You can also create a custom policy to grant read permissions such as SELECT.
    • Write permission: Grant the write permission of ClickHouse to the IAM user or user group of DataArts Migration through a system policy such as MRS CommonOperations and MRS FullAccess. You can also create a custom policy to grant write permissions such as INSERT INTO TABLE and CREATE TABLE.
    • Enabling ports: When configuring the MRS ClickHouse data source, ensure that the following ports have been enabled in the security group or network so that DataArts Migration can access MRS.
      Table 1 Service ports
      Service
      Port
      Port Number
      Usage
      ClickHouse
      TCP
      9000
      ClickHouse TCP port, which is used by the client to connect to the ClickHouse server
      HTTP
      8123
      ClickHouse HTTP port, which is used by the client to connect to the ClickHouse server
      HTTPS
      8443
      ClickHouse HTTPS port, which is used by the client to connect to the ClickHouse server
      MRS Manager
      TCP
      28443
      Used to download the MRS cluster configuration
      TCP
      20009
      Used for CAS authentication
      TCP
      20029
      Used by Manager to communicate with and manage other components
      Kerberos (KDC)
      TCP&&UDP
      21730
      Used for Kerberos authentication
      TCP&&UDP
      21731
      TCP&&UDP
      21732
      Zookeeper
      TCP
      2181
      ZooKeeper service port used for communications between the client and ZooKeeper cluster
Supported Data Types
The field types supported by different ClickHouse versions vary. The following table lists the field types supported by the open-source ClickHouse version 21.3.4.25. DataArts Migration is compatible with the following field types and their common variants so that it can correctly read and write various types of data.
Category
ClickHouse Field Type
Read
Write
Numeric
Int8
Int16
Int32
Int64
Int128
UInt8
UInt16
UInt32
UInt64
UInt128
Float32
Float64
Decimal
Character
String
FixedString
Time
Date
DateTime
DateTime64
Boolean
Boolean
Array
Array
Tuple
Tuple
x
x
IP
IPv4
IPv6
Enumeration
Enum8
Enum16
Nested
Nested
x
x
Supported Migration Scenarios
DataArts Migration supports the following offline synchronization modes:
  • Single table synchronization
    DataArts Migration supports table/file synchronization in data ingestion into a data lake or data migration to the cloud.
  • Database and table shard synchronization
    DataArts Migration supports synchronization of data from multiple databases and tables in data ingestion into a data lake or data migration to the cloud.
  • Entire DB migration
    DataArts Migrations supports synchronization of data from an on-premises database in data ingestion into a data lake or data migration to the cloud.
Database and table shard synchronization and entire DB migration are not supported in all regions. The following table lists the supported MRS ClickHouse migration scenarios.
Single Table Read
Single Table Write
Database/Table Shard Read
Database/Table Shard Write
Entire DB Read
Entire DB Write
Supported
x
x
x
Core Capabilities
  • Connection configuration
    Configuration Item
    Supported
    Kerberos authentication is used to access MRS clusters.
    Connection configuration optimization
    Connection configuration such as connectTimeout can be optimized to improve connection performance.
  • Read capabilities
    Configuration Item
    Supported
    Shard concurrency
    Horizontal sharding based on primary keys or common fields and multi-thread concurrent extraction significantly improve the throughput and efficiency.
    Dirty data processing
    Abnormal data can be written to the dirty data bucket to prevent job failures caused by a small amount of abnormal data.
    Custom fields
    You can add computed columns, constant columns, or masking functions for tasks to meet personalized service requirements.
    Incremental read
    Where conditions can be used to deliver query requests for incremental data reading.
    Stream and batch reading
    Batch reading
    Data can be read from a large static dataset in batches and then centrally processed.
  • Write capabilities
    Configuration Item
    Supported
    Pre- and post-import processing
    Operations such as preSql can clean and process data before and after data import.
    Concurrent write
    Concurrent write improves efficiency.
    Optimization of the number of written rows
    You can set the number of rows written by each request in the connection to properly control the amount of data to be transmitted. This improves performance and prevents a transmission delay or the system from being overloaded when there is a large amount of data.
    x
    Abnormal data cannot be written to the dirty data bucket to prevent job failures caused by a small amount of abnormal data.
Creating a Data Source
Create a data source in Management Center. For details, see Configuring Data Connection Parameters.
Creating an Offline Data Migration Job
Create a ClickHouse migration job in DataArts Factory. For details, see Creating an Offline Processing Migration Job.
