Configuring an Offline Processing Migration Job
When creating an offline processing migration job, you can select the source and destination data and configure parameters to periodically synchronize all or incremental data of a table, database/table partition, or entire database from the source to a destination table.
This section describes the common configurations of an offline processing migration job. The configuration varies depending on the data source. For details, see Configuring Source Job Parameters and Configuring Destination Job Parameters.
Notes and Constraints
Pay attention to the precision of the field types at the source and destination. If the maximum value of the field type at the destination is less than the maximum value at the source (or the minimum value of the field type at the destination is greater than the minimum value of the field type at the source, or the precision is lower than the precision at the source), the write may fail or the precision may be truncated.
You have completed the self-check. For details, see Performing a Check Before Using an Offline Job.
- Create an offline processing migration job by referring to Creating an Offline Processing Migration Job.
- Configure types. Figure 1 Configuring types
- Set the source connection type and destination connection type. For details about supported data sources, see Overview.
- Set Migration Job Type.
- Migration Type: The default value is Offline and cannot be changed.
- Migration Scenario: Select one from Single table, Database/Table partition, and Entire DB Migration. For details about the supported data sources, see Overview.
- Configure Network Resource Configuration.
- Select a created source data connection (DataArts Migration was selected for the connection). If no connection is available, create one by referring to Creating a DataArts Studio Data Connection.
Check whether the source and the resource group can communicate with each other. If they cannot, modify the network settings as prompted.
- Select a resource group. For details about how to create a cluster, see Creating a CDM Cluster.
If multiple clusters are selected, the system randomly delivers tasks. Therefore, you are advised to select clusters of the same version. Otherwise, the job may fail due to inconsistent cluster versions.
- Select a created destination data connection (DataArts Migration was selected for the connection). If no connection is available, create one by referring to Creating a DataArts Studio Data Connection.
Check whether the data connection is available. If the data connection is unavailable, change another one as prompted.
- Configure source parameters. The configuration varies depending on the data source and synchronization scenario. After selecting a source connection, configure job parameters by referring to Configuring Source Job Parameters.
Table 1 Required source job parameters Scenario
Required Source Parameters
Field Mapping
Single table
- Basic parameters
- Advanced attributes
Supported
- Database/Table mode, exact match or regular expression match
Supported
Entire DB migration
- Database tables to be migrated
Not supported
- Configure destination parameters. The configuration varies depending on the data source and synchronization scenario. After selecting a destination connection, configure job parameters by referring to Configuring Destination Job Parameters.
Table 2 Required destination job parameters Scenario
Required Destination Parameters
Field Mapping
Single table
- Basic parameters
Supported
- Basic parameters
Supported
Entire DB migration
Database and table matching policy
Not supported
- Configuring field mapping.
After configuring source and destination parameters, you need to configure the mapping between source and destination columns. After the field mapping is configured, the job writes source fields to fields of the corresponding types at the destination based on the field mapping.
- Field mapping configuration: Set the field mapping mode and batch field mapping rule.
- Field Mapping Mode
- Same name: Fields with the same name are mapped. Fields with the same column name are automatically mapped.
- Same row: Fields with different names but in the same row of the source and destination table are mapped. Source and destination fields in the same row are automatically mapped.
- Batch Field Mapping: This parameter is not displayed when Use SQL Statement in the source configuration is set to Yes.
Enter field mappings, with one field mapping in each row. Place fields from the source table to the left of the equal sign (=) and fields from the destination table to the right of the equal sign (=), for example, reader_column=writer_column.
Click View and Edit to set the batch field mapping.
- Field mapping: batch conversion, field adding, and row moving
- Sensitive information detection: Check whether the source data contains sensitive information. If there is sensitive information, data cannot be migrated, and you need to modify the information as prompted.
- Set Converter: Convert source fields in batches.
Select the target fields and click Set Converter. In the displayed dialog box, create a converter as prompted.
- Delete Field: This parameter is unavailable when Use SQL Statement in the source configuration is set to Yes. Select the target fields and click Delete Field.
You can view the deleted fields in Removed Fields in the Add Field dialog box.
- Add Field: This parameter is unavailable when Use SQL Statement in the source configuration is set to Yes. You can add new fields or removed fields to the source and destination configurations.
The following types of fields are supported:
- Functions, such as now() and curdate() for MySQL, and now() and transaction_timestamp() for PostgreSQL
- Functions with keywords, for example, to_char(current_date,'yyyy-MM-dd') for PostgreSQL
- Fixed values, such as 123 and '123' (both indicate string 123)
- Variable values, for example, ${workDate} (workDate must be defined in the job variable.)
- Fixed variables for JDBC, such as DB_NAME_SRC (source database name), TABLE_NAME_SRC (source table name), and DATASOURCE_NAME_SRC (data source name)
- as statements are supported, such as '123' as test and now() as curTime.
- Move rows: This function is unavailable when Use SQL Statement in the source configuration is set to Yes. Drag the row of a field and move the row up or down.
- View converters: (Optional) CDM can convert fields. Click
and then click Create Converter. For details about how to use converters, see Configuring Field Converters. - Search for and match destination fields: Click
in the Operation column. In the displayed dialog box, search for a field by keyword or click a field directly. - Delete fields: You can delete the default fields of the table. To delete a field, click
in the Operation column. Removed fields can be found in Removed Fields in the Add Field dialog box. - Example Field Mapping: This parameter is not displayed when Use SQL Statement in the source configuration is set to Yes. You can view the example mapping of source and destination fields.
- If files are migrated between FTP, SFTP, OBS, and HDFS, and the migration source's File Format is set to Binary, files will be directly transferred, free from field mapping.
- Field mapping configuration is not required for entire DB migration.
- During the migration, the field types at the source and destination may not match. As a result, dirty data is generated, and data cannot be written to the destination. For details about the number of dirty data records allowed during the migration, see the next step.
- If a field at the source is not mapped to a field at the destination, the field at the source will not be synchronized to the destination.
- In other scenarios, CDM automatically maps fields of the source table and the destination table. You need to check whether the mapping and time format are correct. For example, check whether the source field type can be converted into the destination field type.
- If the field mapping is incorrect, you can drag fields to adjust the mapping. (This function is supported when Use SQL Statement in the source configuration is set to No.)
- If you cannot obtain all columns by obtaining sample values on the field mapping page, you can click
to add a custom field or click
in the Operation column to create a field converter to ensure that all required data can be imported to the destination. - In the Field Mapping area, you can click
to add custom constants, variables, and expressions. - The column name is available only the Extract first row as columns parameter is set to Yes during the migration of a CSV file from OBS.
- When SQLServer is the destination, fields of the timestamp type cannot be written. You must change their type (for example, to datetime) so that they can be written.
- If the data is imported to DWS, you need to select the distribution columns in the destination fields. You are advised to select the distribution columns according to the following principles:
- Use the primary key as the distribution column.
- If multiple data segments are combined as primary keys, specify all primary keys as the distribution column.
- In the scenario where no primary key is available, if no distribution column is selected, DWS uses the first column as the distribution column by default. As a result, data skew risks exist.
- Configuring task properties.
You can configure the parameters listed in Table 3 for data synchronization.
- Save the job.
After configuring the job, click Save in the upper left corner to save the job configuration.
If real-time sensitive information detection is enabled for a job, the system automatically checks whether the source data contains sensitive information. If there is sensitive information, data cannot be migrated. In this case, you must make modifications as prompted.
After the job is saved, a version is automatically generated and displayed in Versions. The version can be rolled back. If you save a job multiple times within a minute, only one version is recorded. If the intermediate data is important, you can click Save new version to save and add a version.
- Test the job. After configuring the job, click Test in the upper left corner to test the job. If the test fails, view the logs of the job node and locate and rectify the fault.
- A test execution is similar to a single execution and migrates data.
- You can view the test run logs of the job by clicking View Log.
- If you test the job before submitting a version, the version of the generated job instance is 0 on the Job Monitoring page.
- Submit a job version.
If you want the job to be scheduled periodically, you need to release the job to the production environment. For how to release a job, see Releasing a Job Task.
Figure 2 Submitting the job
- Schedule the job.
Set the scheduling mode for the job. For details about how to schedule the job, see Setting Up Scheduling for a Job.
