RDS(SQL Server) Connection Parameters
RDS(SQL Server) connections can connect to databases such as RDS for SQL Server and on-premises SQL Server databases.
| Parameter | Mandatory | Description |
| Data Connection Type | Yes | For RDS(SQL Server) connections, RDS(SQL Server) is selected and cannot be changed. |
| Name | Yes | Name of the data connection to create. Data connection names can contain a maximum of 100 characters. They can contain only letters, digits, underscores (_), and hyphens (-). |
| Description | No | A description which can help identify the data connection more easily. It can contain a maximum of 100 characters. |
| Tag | No | Attribute of the data connection to create. Tags make management easier. NOTE: The tag name can contain only letters, digits, and underscores (_) and cannot start with an underscore (_) or contain more than 100 characters. |
| Applicable Modules | Yes | Select the modules for which this connection is available. NOTE:
| Basic and Network Connectivity Configuration | ||
| IP Address or Domain Name | Yes | Address for accessing the relational database through an internal network. Enter an IP address or domain name.
| Port | Yes | Port for accessing the relational database Ensure that you have enabled this port in the security group rule so that the DataArts Studio instance can connect to this database through this port.
| KMS encryption key | Yes | KMS key used to encrypt and decrypt data source authentication information. Select a default or custom key. NOTE:
| Agent | Yes | RDS is not a fully managed service and cannot be directly connected to DataArts Studio. A CDM cluster can provide an agent for DataArts Studio to communicate with non-fully-managed services. Therefore, you need to select a CDM cluster when creating an RDS data connection. If no CDM cluster is available, create one first by referring to Creating a CDM Cluster. As a network proxy, the CDM cluster must be able to communicate with RDS. To ensure network connectivity, the CDM cluster must be in the same region and AZ and use the same VPC and subnet as RDS. The security group rule must also allow the CDM cluster to communicate with RDS. NOTE: If a CDM cluster functions as the agent for a data connection in Management Center, the cluster supports a maximum of 200 concurrent active threads. If multiple data connections share an agent, a maximum of 200 SQL, Shell, and Python scripts submitted through the connections can run concurrently. Excess tasks will be queued. You are advised to plan multiple agents based on the workload. |
| SSL Encryption | No | Whether to enable SSL encryption |
| Data Source Driver Configuration | ||
| Driver Name | Yes | com.microsoft.sqlserver.jdbc.SQLServerDriver: Select this driver name for SQL Server. |
| Driver File Path | Yes | It specifies the OBS path where the driver file is located. You need to download a .jar driver file from the corresponding official website and upload it to OBS. SQL Server driver: Download it from https://learn.microsoft.com/en-us/sql/connect/jdbc/download-microsoft-jdbc-driver-for-sql-server?view=sql-server-ver16. The 8.4.1 version is recommended. NOTE:
| Data Source Authentication and Other Function Configuration | ||
| Username | Yes | Username of the database. The username is required for creating a cluster. |
| Password | Yes | Password for accessing the database. The password is required for creating a cluster. |
| DataArts Migration Configuration | ||
| Database Name | Yes | Name of the database to connect |
| Fetch Size | No | Set the number of rows obtained by each request. Set this parameter based on the data source and the job's data size. This parameter is optional. If the value is either too large or too small, the job may run for a long time. The default value is 1000. |
| Link Attributes | No | This parameter is optional. Click Add to add the JDBC connector attributes of multiple specified data sources. For details, see the JDBC connector document of the corresponding database. Examples for SQL Server:
| Reference Sign | No | (Optional) Delimiter between the names of the referenced tables or columns. For details, see the product documentation of the corresponding database. The default value is ". |
