Updated on 2026-08-17 GMT+08:00
SFTP/FTP Connection Parameters (Internal Test)
Table 1 SFTP/FTP connection
Mandatory
Data Connection Type
Yes
The value is fixed at SFTP or FTP.
Name
Yes
Name of the data connection to create. Data connection names can contain a maximum of 100 characters. They can contain only letters, digits, underscores (_), and hyphens (-).
No
A description which can help identify the data connection more easily. It can contain a maximum of 100 characters.
Tag
No
Attribute of the data connection to create. Tags make management easier.
The tag name can contain only letters, digits, and underscores (_) and cannot start with an underscore (_) or contain more than 100 characters.
Applicable Modules
Yes
Select the modules for which this connection is available.
  • When offline or real-time data migration jobs are enabled, you can select the DataArts Migration module. Then you can select this data connection when creating a data migration job in DataArts Factory.
  • You can use offline or real-time data migration jobs only after you apply for the whitelist membership. To use this feature, contact customer service or technical support.
Network Connectivity Configuration
Host Name/IP Address
Yes
This parameter is displayed when DataArts Migration is selected for Applicable Modules. Host name or IP address of the server
Example: sftp.apache.org or 192.168.0.1
Port
Yes
SSH port number of the host
Data transfer timeout
Yes
This parameter is displayed when DataArts Migration is selected for Applicable Modules. Timeout duration for connecting to the server during data transmission, in milliseconds
The default value is 600000.
KMS encryption key
Yes
KMS key used to encrypt and decrypt data source authentication information. Select a default or custom key.
  • When you use KMS for encryption through DataArts Studio or KPS for the first time, the default key dlf/default or kps/default is automatically generated. For more information about default keys, see What Is a Default Master Key?.
  • Only symmetric keys are supported. Asymmetric keys are not supported.
Agent
Yes
DataArts Studio cannot directly connect to non-fully managed services. An agent is required for DataArts Studio to communicate with non-fully managed services. A CDM cluster can function as an agent. If no CDM cluster is available, create one by referring to Creating a CDM Cluster.
Data Source Authentication and Other Function Configuration
Username
Yes
Username for connecting to the SFTP/FTP server
Key Pair Password
Yes
Key pair password for connecting to the SFTP/FTP server
