To HBase
Type |
Parameter |
Description |
Example Value |
Basic parameters |
Table Name |
Name of the table to which data will be written. Click the icon next to the text box. The dialog box for selecting the table is displayed. This parameter can be configured as a macro variable of date and time and a path name can contain multiple macro variables. When the macro variable of date and time works with a scheduled job, the incremental data can be synchronized periodically. For details, see Incremental Synchronization Using the Macro Variables of Date and Time.
If you have configured a macro variable of date and time and schedule a CDM job through DataArts Studio DataArts Factory, the system replaces the macro variable of date and time with (Planned start time of the data development job – Offset) rather than (Actual start time of the CDM job – Offset). |
table |
Clear Data Before Import |
Whether to clear table data before import Yes: Table data will be cleared before import. No: Table data will not be cleared before import. |
No |
Advanced attributes |
Rowkey Data Redundancy |
Whether to write rowkey data to the HBase column at the same time |
No |
Write WAL |
Whether to write WALs. If this is disabled, performance can be improved, but data may be lost when HBase breaks down. |
Yes |
Type Match |
Whether to match the data type, for example, whether column data of the int type in the database will be converted into binary data before written to HBase. |
No |
