Updated on 2025-04-09 GMT+08:00
From MongoDB
MongoDB data sources with SSL enabled are not supported.
Table 1 Parameter description
Type
Mandatory
Example Value
Basic parameters
Database
Enter or select a database name. Click the button next to the text box to enter the page for selecting a set.
Yes
default
Collection Name
Enter or select a collection name. Click the button next to the text box to enter the page for selecting a collection.
This parameter can be configured as a macro variable of date and time and a path name can contain multiple macro variables. When the macro variable of date and time works with a scheduled job, the incremental data can be synchronized periodically. For details, see Incremental Synchronization Using the Macro Variables of Date and Time.
If you have configured a macro variable of date and time and schedule a CDM job through DataArts Studio DataArts Factory, the system replaces the macro variable of date and time with (Planned start time of the data development job – Offset) rather than (Actual start time of the CDM job – Offset).
Yes
table
Advanced attributes
query filters
Filter used to match documents
Example: {HTTPStatusCode:{$gt:"400",$lt:"500"},HTTPMethod:"GET"}
No
