To OBS
Files (even in a large volume) can be batch migrated to OBS in CSV, CarbonData, or binary format.
Type | Parameter | Description | Example Value |
Basic parameters | Bucket Name | Name of the OBS bucket to which data is to be written | bucket_2 |
Write Directory | OBS directory to which data will be written. Do not add / in front of the directory name. This parameter can be configured as a macro variable of date and time and a path name can contain multiple macro variables. When the macro variable of date and time works with a scheduled job, the incremental data can be synchronized periodically. For details, see Incremental Synchronization Using the Macro Variables of Date and Time. NOTE: If you have configured a macro variable of date and time and schedule a CDM job through DataArts Studio DataArts Factory, the system replaces the macro variable of date and time with (Planned start time of the data development job – Offset) rather than (Actual start time of the CDM job – Offset). | directory/ | |
File Format | Format used for transmitting data. The CSV and JSON formats are supported for migration to tables, and the binary format is supported for file migration. Format in which data is written. The options are as follows:
If data is migrated between file-related data sources, such as FTP, SFTP, HDFS, and OBS, the value of File Format must the same as the source file format. NOTE:
| CSV | |
Duplicate File Processing Method | This parameter is unavailable when File Format is CSV.
| REPLACE | |
Advanced attributes | Field Delimiter | Field delimiter in the file. This parameter is not used when File Format is set to Binary. | , |
File Size | This parameter is displayed only when the migration source is a database. Files are partitioned as multiple files by size so that they can be exported in proper size. The unit is MB. | 1024 | |
Encode type | Encoding type, for example, UTF-8 or GBK. This parameter is not used when File Format is set to Binary. | GBK | |
First Row As Header | This parameter is displayed only when data is exported from a relational database to OBS and File Format is set to CSV. When a table is migrated to a CSV file, CDM does not migrate the heading line of the table by default. If you set this parameter to Yes, CDM writes the heading line of the table to the file. | No | |
Validate MD5 Value | Calculate the MD5 value of the source files and verify it with the MD5 value returned by OBS. This parameter is displayed only when File Format is set to Binary. If an MD5 file exists at the migration source, the system directly reads the MD5 file from the source and verifies it with the MD5 value returned by OBS. | No | |
Record MD5 Verification Result | This parameter is displayed only when File Format is set to Binary. It specifies whether to write the MD5 verification result to OBS and record the verification result of each file. | No | |
Job Success Marker File | Whether to generate a marker file with a custom name in the destination directory after a job is executed successfully. If you do not specify a file name, this function is disabled by default. | finish.txt | |
Use Quote Char | This parameter is displayed only when File Format is CSV. It is used for migrating database tables to file systems. If you set this parameter to Yes and a field in the source data table contains a field delimiter or line separator, CDM uses double quotation marks (") as the quote character to quote the field content as a whole to prevent a field delimiter from dividing a field into two fields, or a line separator from dividing a field into different lines. For example, if the hello,world field in the database is quoted, it will be exported to the CSV file as a whole. | No | |
Customize Hierarchical Directory | If this parameter is set to Yes, the files after migration can be stored in a custom directory. That is, only files are migrated. The directories to which the files belong are not migrated. | Yes | |
Hierarchical Directory | Custom storage directory for files after migration. The time macro variable is supported. NOTE: If the source link is a relational database link, the directory name consists of the source table name and a custom directory name. In other scenarios, the directory is a custom directory. | ${dateformat(yyyy-MM-dd HH:mm:ss, -1, DAY)} | |
Compression Format | This parameter is unavailable when File Format is CSV. The options are as follows:
| NONE | |
Encryption | Whether to encrypt the uploaded data and the encryption mode. The options are as follows:
For details, see Encryption and Decryption During File Migration. | KMS | |
KMS ID | Data encryption key. This parameter is displayed when Encryption is set to KMS. Click
| 53440ccb-3e73-4700-98b5-71ff5476e621 | |
Project ID | ID of the project to which KMS ID belongs. The default value is the ID of the project to which the current CDM cluster belongs.
| 9bd7c4bd54e5417198f9591bef07ae67 | |
Copy Content-Type | This parameter is displayed only when File Format is set to Binary. Whether to copy the Content-Type attribute of the source file during object upload. This attribute is mainly used for static website migration. It cannot be written to the Archive bucket. | No | |
Custom File Name | This parameter is displayed only when data is exported from a relational database to OBS and File Format is set to CSV. This parameter specifies the name of the file generated by OBS. The options are as follows:
| cdm | |
Blob | This parameter is available only when data is exported from a relational database to OBS. If this function is enabled, generated files are named in the following format: Root directory-Table name-Data type-Data folder format. Example: raw_schema/tbl_student/datas/tbl_student_1.csv | No | |
Blog File Name Extension | This parameter is available only when Folder Mode is set to Yes. It specifies the extension for the names of the files that contain custom Blog/Clog data in folder mode. | .dat/.jpg/.png |
