To Hive
Data can be rapidly imported to MRS Hive.
Type | Parameter | Description | Example Value |
Basic parameters | Database | Database name. Click the icon next to the text box. The dialog box for selecting the database is displayed. | default |
Table Name | Destination table name. Click the icon next to the text box. The dialog box for selecting the table is displayed. This parameter can be configured as a macro variable of date and time and a path name can contain multiple macro variables. When the macro variable of date and time works with a scheduled job, the incremental data can be synchronized periodically. For details, see Incremental Synchronization Using the Macro Variables of Date and Time. NOTE: If you have configured a macro variable of date and time and schedule a CDM job through DataArts Studio DataArts Factory, the system replaces the macro variable of date and time with (Planned start time of the data development job – Offset) rather than (Actual start time of the CDM job – Offset). | TBL_X | |
Hive Write Mode | Mode of writing data to Hive
| LOAD_OVERWRITE | |
Partition Values | In TRUNCATE mode, multiple partitions are supported. You only need to enter values in the corresponding text boxes. In LOAD_OVERWRITE mode, data can be written to only one partition. | N/A | |
Advanced attributes | Source side null value conversion value | Null value conversion type
| TO_NULL |
Newline character processing mode | Policy for processing the newline characters in the data written to Hive textfile tables. You can select Delete, Replace with another character string, or Do not process. | Delete | |
Newline Replacement String | This parameter is available when Processing mode of newline characters is set to Replace with another character string. It indicates the string that will replace newline characters. | N/A | |
Executing Analyze Statements | After all data is written, the ANALYZE TABLE statement is asynchronously executed to accelerate the Hive table query. The SQL statement is as follows:
| Yes |
