Updated on 2025-11-18 GMT+08:00
From Kafka
Table 1 Parameter description
Type
Example Value
Basic parameters
Topic
Topic name. You can add a single topic.
cdm_topic
Data Format
Format used for parsing data. The options are as follows:
  • JSON: Source data will be migrated after being converted in JSON format.
  • CSV: Source data will be migrated after being converted in CSV format.
JSON
Consumer Group ID
Consumer group ID
If you export data from DMS Kafka, enter any value for Kafka Platinum but a valid consumer group ID for Kafka Basic.
consumer-group
Consumption Record Policy
Consumption record policy
  • Start/End Time: Check whether the extracted records are within the specified start time and end time based on the Kafka record metadata TIMESTAMP. When the end time of the consumed record arrives, the extraction task is terminated. The start time is included and end time is excluded. It can be used together with scheduling tasks.
  • Earliest: Data is consumed from the start point.
  • Latest: Data is consumed from the last point. Submitted indicates that data has been submitted. The start/end time, waiting time, and maximum extraction time are independent of each other. If any of the conditions is met, the Kafka extraction ends.
Start/End Time
Minimum Timestamp
This parameter is mandatory if the Consumption Record Policy is set to Start/End Time.
The format is yyyy-MM-dd HH:mm:ss. This parameter can be used together with variables in DataArts Factory.
2024-07-25 00:00:00
End Time
2024-07-25 23:59:59
Wait Data Timeout
Time (in minutes) to wait before the task stops when null is returned for a data acquisition request from the consumer
30s
Pull Data Runtime
Maximum extraction time for the consumer, in minutes
It indicates the maximum duration for Kafka to extract data from the consumer end. When the duration ends, the extraction is forcibly terminated. If this parameter is not set, the default value 30 min is used.
1440
Field Delimiter
Field delimiter during migration. The default value is a space.
Record Delimiter
Currently, the following special characters cannot be used as separators: @||$.
Example
You can use the start and end policies of Kafka together with the scheduling capability to implement periodic incremental synchronization. You can enable incremental data extraction from Kafka by hour or day using the start and end policies and periodic scheduling.
For example, if you want to write newly generated Kafka data to Hive every hour to implement periodic incremental data ingestion into the lake, perform the following operations:
  1. Configure job parameter variables.
    • Start time: startTime:#{DateUtil.format(DateUtil.addHours(Job.planTime,-1),"yyyy-MM-dd HH:mm:ss")}
    • End time: endTime:#{DateUtil.format(Job.planTime,"yyyy-MM-dd HH:mm:ss")}
      startTime indicates the one hour before the task scheduling time, and endTime indicates the scheduling time.
      Figure 1 Example
  2. Configure the task for reading Kafka data.
    Set Consumption Record Policy to Time Range, Start Time to ${startTime}, and End Time to ${endTime}.
    Figure 2 Configuring a consumption record policy
  3. Set the task to be executed every hour.
